Question about Dell Vostro 1510 Laptop
My Dell Vostro Boots in BIOS mode and then it checks for the Hard Disc, CD Rom after which it shows colour full verticle & horozinta line and asks weather you are able able to see the colour line if then Press (yes/No). but when I press Yes Or No it doe not react to it, after some time ther is beep sound. kinldy help
  • 3,940 Answers
Most likely a bad hard drive
Posted on Sep 10, 2010
My Dell Windows 7 laptop won't boot?
Press the Delete key during start up, to enter its bios settings window. At boot sequence selection, select CD ROM as first boot device, Hard disc to second boot device, and deselect all other boot devices. Means, there should be only CD ROM and Hard disc as boot devices, as said above, in sequence. Select 'Save and reboot' at the bios option, the computer will restart with hard disc; provided there is no CD at CD ROM. Gopakumar Gopalan Google
May 10, 2014 | Dell Computers & Internet
PC turns on but will not boot up; unable to run directly from cd rom
Just before it boots, press the button, (F1. F2, Esc etc) to gain bios screen. Set the boot drive to DVD ROM. Insert your boot disc and re boot.
Nov 21, 2013 | Dell Inspiron 1545 Notebook
I'm having this Dell Vostro 1510. Its not getting booted. When i try to boot it, It opens bios setting automatically with sometime beep sound coming. I tried to boot in safe mode, safe mode with...
insert the cd into the cd rom, when dell logo appears start tapping F12 it will give you the option to boot directly from cd.
also you can try system recovery if you have recovery partition with ctrl+F11.
Aug 06, 2011 | Dell Vostro 1510 Laptop
Dell Vostro 1310 - when turned on screen still blank, numlock blinking, capslock and scroll lock light on and stable. tried changed new RAM,issue still persist. whats wrong with it?
it may be bios problem or loose connection with Hard disc... So, follow the below steps: 1.remove the battery and power adapter 2.press the power on button 2 minutes 3.replace the battery 4.now on the laptop normally... now see the result.... ---------------------------------------------------------- if not solved then follow the below steps
1.remove the battery and power adapter 2.remove the hard disc,cd/dvd drive 3.replace the battery 4.now on the laptop normally... 5.if any display appears then problem with ur hard disc or cd/dvd drive.
------------------------------------------------------ follow the below steps to check the problem with your hard disc or cd/dvd drive
1.remove the battery and power adapter 2.remove the hard disc,cd/dvd drive 6.connect the cd/dvd drive 3.replace the battery 4.now on the laptop normally... 5.if any display appears then the cd/dvd drove has no problem,then problem with ur hard disc drive. ---------------------------------------------------
Apr 17, 2010 | Dell Vostro 1310 Laptop Computer PC...
Show a blue screen
You need to go into the Setup Utility or BIOS when the computer boots. You need to enable the computer to boot from the CD drive, and set up boot priority with CD Drive first, then Hard Drive HDD.
Then it will boot the disc.
Dec 17, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
I have a Dell Dimension 4600. I need to re-install Windows XP Professional. The PC won't boot from the CD-ROM. When I choose F12, then Boot from IDE CD-ROM, the PC boots directly to Windows. how can I get...
Check the BIOS to make sure that the CD rom is the first boot devices in the bootup sequence, also make sure that the cd rom does show up in the BIOS.
Make sure that the CD Rom itself is good or the boot cd you are using is good, try it on other PC.
Oct 29, 2009 | Dell Dimension 4600 PC Desktop
Windows file is corrupted and can not boot up computer
Hardrive is most likely faulty or your memory sticks are bad or not completely inserted. If you are able to turn on pc, press f2 or f8 as soon as it boots, then insert bios mode, change bootup settings for CD-ROM as first bootup device, then Hard Disc as second bootup device, then insert your windows installation disc or recovery cd, insert it, restart pc and run the disc to install windows.
Oct 06, 2009 | Dell Celeron, 300 MHz (2997D) Processor...
Internal hard drive not found dell inspirion
Try re-booting the system in safe mode and go to my computer->manage->hard drive..try to refresh it from there.
Sep 05, 2009 | Dell Inspiron 2200 Notebook
Do not recognize any cd/dvd in dell vostro 1510 bios A13
i have dell vostro 1510 labtop < bought from SA 2 y ago, dvd rom not work, always rejected when inserted, also bluetooth and toutch pad not recognized, i use windows 7
find me a solution
Jan 24, 2009 | Dell DVD-rom DVD Drive
Dell Vostro 1510 Laptop Logo
75 people viewed this question
Alun Cox
