Question about Taylor Body Fat Analyzer & Scale, Model 5571
When using the scale the for first time each day, the weight reading is usually 2 lb low. Stepping off the scales, waiting for the reading to reset, stepping back on usually results in a reading 2 lb heavier. Repeating this sequence produces somewhat consistent results. (2 lb heavier than fist reading) Scales are used on a level tile floor Scales is 2 years old and is used daily Do you have any idea why the first reading reads low? Scale is Taylor model 5571 Thank You Bob Christie
r321567499
  • 74 Answers
SOURCE: Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
  • 3 Answers
SOURCE: Need an owners manual for taylor mod 5757 bathroom scales
Summary of my manual: you need to initialize it first. Tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be initialized...
Instructions for set up are:
  • Turn it on.
  • Select user number using up and down buttons (P0 through P9 can be used).
  • Hit the Set button.
  • Choose gender using up and down buttons.
  • Enter your age using up and down buttons.
  • Enter your height (goes in 1/2 inch increments) using up and down buttons.
  • Hit the Set button. (Info is now saved.)
  • When scale changes to 0.0, you can step on, and get your weight.
  • It will blink and change weight possibly for a second or two. When it stops, it shows your weight.
  • Stay standing still on the scale after your weight, and it will gon to show your bodyfat percentage, then your body water percentage.
  • When finished, you can step off, and it will turn off.
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact
Posted on Oct 17, 2009
  • 58 Answers
SOURCE: taylor scales model 7314 lithium scale
Have you tried to email Taylor Customer Help and Support?
They are very useful. They can guide you through problems, provide you with instructions and might send the user manual via email.
I hope you get this fixed. Scales are very tricky!
Posted on Oct 25, 2009
SOURCE: how to calibrate a taylor scale 5571
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Posted on Nov 29, 2009
skaterkid307
  • 86 Answers
SOURCE: How can I fix the Taylor LIthium Scale?
take it to were you got it or instuctions show u
Posted on Feb 20, 2010
Dashes
I have a Health-o-meter but not the same model. Mine still has the instructions pasted (loosely) to the bottom.
The secret is that you must initially press the lower (left or right side) corer for just a second or two. That causes a few dashes and then the scale reads 00.0. Then get on the scale and get your reading.
Alternative behavior:
If you initially press the corner for more than a few seconds it will cycle through User Numbers one through four. If you use that feature it remembers your weight from the last time so you can see the difference.
Apr 15, 2014 | Health-O-Meter Health o meter 844KL...
Shows 0.0lb no weight
Well I figured it out, just in case anyone comes across this. Turn it over, push the button on the top middle of the scale, hold, turn back over, wait until "C" appears on the screen, stand on scale, now it works. :)
Jan 10, 2012 | Taylor Biggest Loser 7206 Electronic Cal...
Scale keeps showing lo no weight
Try taking the battery out and putting it back in, also there should be a small reset button. You will need a toothpick to push the reset button. Allow time for the scale to reset before stepping on it.
Apr 19, 2011 | Homedics Digital Scale
I get an "E" every time i step on scale
Stepping on the scale before the "000.0" causes this error message to appear. If "E" appears, step off the scale and repeat initial RESTART by tapping on the center of the scale. Wait for the scale to indicate 00.0 or something like that THEN step on.
Oct 12, 2010 | Health-O-Meter Health O Meter HDM520KD 18...
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 15, 2010 | Health & Beauty
Nothing will display on the read out
Jan 03, 2010 | Taylor Dgtl Body Fat Scale
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Apr 24, 2009 | Conair WW60 Weightwatchers Scale
Can I reset the scale?
This link allows you to ask questions and request a users manual....I hope this helps. http://www.conair-store.com/cc_contactus.asp
Dec 31, 2008 | Conair WW60 Weightwatchers Scale
Taylor Body Fat Analyzer & Scale, Model 5571 Logo
24 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
