Question about Mitsubishi WT-46805 46" Rear Projection Television
Ticking with no picture, Won't turn on - Mitsubishi WT-46805 46" Rear Projection Television
  • 1 more comment
  • Lisa Answeeney
    Lisa Answeeney Sep 10, 2010
    Thanks Rylee, but that didn't work, the power won't stay on to the Tv, it clicks when hitting the power then makes another click from the rear?
  • Lisa Answeeney
    Rylee,
    Still doing it, It was plugged in to a surge protector, but now it's in the wall. It won't stay on. When I turn the power on the light comes on and then immediately goes off and that's when I hear the ticking from the back? Thanks, Lisa
  • Lisa Answeeney
    Okay, Rylee,
    That did it, It's backing working, I have a blue screen, but I think I can figure the rest out!!! Appreciate the advice.... Thanks, Lisa
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You’ll need to reset it. To reset the TV turn it off and wait for 5 minutes. After 5 minutes unplug the television power cord from the electrical outlet and let the television remain without power for more then 1 minute. Plug the power cord back into the electrical outlet. If the television is plugged into a power surge protector, remove it from there and plug it directly into the wall outlet. Turn on the television. If the issue is resolved, then the problem is with the power surge protector and not the television. If the issue is not resolved then this might have happened due to over-voltage. Please check the power supply unit for swollen/ bulged capacitors and burnt wires/components on the power supply board. Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in off condition. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 10, 2010
  • Rylee Smith
    Rylee Smith Sep 10, 2010
    Thanks for your reply Lisa, the issue seems to be with the fuse going bad or the power supply board itself is bad and you need to get it checked.
  • Rylee Smith
    OK Lisa, Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Won't stop ticking!!!! Why??
The noise could be from the expansion and contraction of the metal from heating up and cooling down. You could try loosen the mounting screws of the unit slightly to see if that helps.
Dec 14, 2012 | Williams (5009622) Ceramic Gas Wall...
The battery goes dead won't even jump and turn
the clicking sound is the starter relay check battery starter motor and this clicking relay hope this helps ivan
Oct 15, 2012 | Cars & Trucks
I have the pth5498 and my tv won't turn on. My
Timer is not the problem---the tick ticking sound is the shutdown circuit in the set that has been triggered by a short somewhere likely in the high voltage area or the convergence circuit---shop repair---says Akai but I suspect set was made by Samsung who owned that name at one time.
May 25, 2012 | Akai Televison & Video
Hi my rca p52937 won't turn on and is making a
The ticking sound is almost always caused by the Flyback and Hot transistor. It could be other items also located on the deflection board but flyback is most likliest. You can get a replacement flyback and Hot tarnsistor from www.tvrepairworld.com
Jul 07, 2011 | RCA Televison & Video
Sharp 2DR-S100S Ticking sound, will not turn on
does it tick all the time are just a few minutes and can you turn it off and back real qiuck and see or hear high voltage come on are see a flash is sounds like you have what is know as startup are shutdown circuit trouble
Feb 22, 2009 | Sharp 25R-S100 25" TV
Green flashing power light and ticking noise but wont turn on
Did you touch the Lamp? If you did it may have blown. the color wheel may be the problem or yes the balist
Jul 25, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Ticking sound when turned on.
Sent me the serial number, and I can check for any re-call ...
my e-mail is <ultraman_s@yahoo.com>
Oct 29, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
