I have a Roland PCR-1 midi controller with a defective component on the PCR-1 PANEL BOARD 00. It is the small coil adjacent to the USB socket, marked L18. One of the legs has detached and I need to replace it..but cannot see the value of the component...can I get a schematic/wiring diagram with component values?
  • 3,083 Answers
I went to my favorite site, but your unit, per se, wasn't there. There are a lot of service manuals, however, for other devices, and the USB coil will be the same value, if they employ that device. You might be able to figurfe out the part number from that.
http://www.eserviceinfo.com/service_manual/datasheets_r_1100.html
Otherwise, you will have to conact Roland for some help. Of course, they will want you to have it serviced, but might help you figure out the part and where to get it.
Here's their support site:
http://www.rolandus.com/products/productdetails.php?ProductId=799
Just wondering, does it look like you can resolder the part?
That would be easier, I think...
Here is a list of parts suppliers, in case you can figure out a part number:
http://www.repairfaq.org/sam/srvcprts.htm
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 10, 2010
How do I change MIDI Channels to coincide with my MIDI controller
Your best bet would be to ask Roland. Here is their link-
https://www.roland.com/us/company/contact_us/ Roland Company Contact Us Contact Us
Feb 27, 2016 | Roland Music
M-Audio MIDI Keyboard Controller's Loose USB Port
Open up and solder in a new Type-B USB socket. Get spare from any electronics parts supplier - it is a generic part. Just 4 solder points on PCB board.
Jul 15, 2014 | M-Audio Axiom 25 2nd Gen 25-Key USB MIDI...
Roland e09 read "midi error" when connected with
If you have the version 1 cable you need to download a driver. The details are at this link:http://www.cme-pro.com/en/news-detail.php?news_id=105
Nov 08, 2010 | Roland Juno-D
How do i hook it up can it be used threw the usb or does it have to be connected with midi
As far as I can tell it will connect with USB as it has a USB connection.
Nov 17, 2009 | Edirol PCR-50 Keyboard
I have just aquired a Roland E-20 synthesizer which I am very pleased with, however, it doesn't have acoustic piano in the tone settings. Is it therefore possible to programme 'acoustic piano' onto the...
They use pre-programed chips. You will have to use the midi out feature to control another midi capable sound module or midi in to a computer and use the internal sound card.
Oct 24, 2009 | Music
Roland RD-700SX as MIDI keyboard
Theres a good article at recordingreview.com. If you join which is free you have access to a lot of great information. You can download Midiox to troubleshoot your midi connections etc. Make sure that your transmit channel on your keyboard matches up with the receive channel in your program. Hope this helps.
Jul 16, 2009 | Music
Sound module & mic (connected to a Tascam US-224) not working
I may be able to help.  I am a longtime Mac and Tascam control surface user.  I am currently running a MacBook Core 2 Duo 2.0GHz running OS 10.5.6 with a Tascam FW-1884 audio interface/mixer/control surface connected.
Setup is fairly easy in the Mac OS.  Here are the steps I'd follow:
NOTE: Before beginning the following process make sure that ALL of your MIDI gear is connected.
- Tascam connected to USB port of computer
- MIDI Keyboard "OUT" connected to Tascam "IN"
- Roland "IN" connected to Tascam "OUT"
1) Open your "Applications" folder.
2) Open the "Utilities" folder.
3) Double-click on "Audio MIDI Setup."
4) At the top of the window select "MIDI Devices"
5) In the pull-down menu on the left select "New Configuration."
6) Title your configuration and press "OK"
7) If your gear has been detected automatically their names and icons should appear in the main window.  If so, skip down to step 12
8) Click on the "Add Device" button
9) Double-click on the "new external device" button that has now been created.
10) Select your device's manufacturer and model (i.e. Roland, JV-1010).
11) Adjust any other settings appropriate to your setup.
[In the main window there should be a Tascam US-224 button.  On it there should be one pair of arrows that indicate the MIDI In and MIDI Out ports of the device.]
12) Click (and hold) on the MIDI Out arrow of the US-224 button.
13) Drag the "cord" and attach it to the MIDI In of the Roland JV-1010 button.
13) Click (and hold) on the MIDI In arrow of the US-224 button.
14) Drag the "cord" and attach it to the MIDI Out of the "keyboard" button.
This should get you setup from a Mac OS/Device routing perspective.  For the appropriate US-224 Control Panel settings refer to the User Manual.
Feb 07, 2009 | Tascam US-224 DIGITAL AUDIO WORK STATION...
Notes don't stop even after I release the key
The keyboard  is not sending a note off instruction after the key is released. Try checking midi preferences in reason.If your using a Mac check that the edirol is present by launching Audio MIDI Setup utility located in the utilities folder. You can download the latest Mac driver from Roland below: EDIROL PCR-300 32-key MIDI Keyboard Controller :: Download
Jan 18, 2009 | Propellerhead Reason 4.0 - Windows and Mac...
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
