I have a 6yr old Kenmore top load washing machine (#8537143A) that filled with water today and then the cycle never went any further. I left the knob pulled out to see if the time would still tick off and the knob isn't moving. I now have a washing machine full of a wet load of laundry. The breakers have not tripped. I plugged into a known working outlet and that didn't do anything. If I move the setting to a larger load it will start adding more water but never continues past that part of the cycle.
  • mlhendric245
    mlhendric245 Dec 11, 2012
    I have the exact same problem, is there a solution?
  • Tracy Van Anda
    Tracy Van Anda Feb 16, 2016
    We have the issue too
  • 641 Answers
SOURCE: top loading automatic washing machine not filling
Check the filters on both sides of the inlet water line. Let me know with your results for further assistance if will be needed. Good luck!
Posted on Aug 31, 2007
SOURCE: Whirlpool Inglis IP44002 Top Loading Washer
What I tried was pushing the lid down and I could hear the machine trying to kick into a spin so then while pressing the lid down i rotated to cycle knob slightly ahead and the spinning started. So I geuss I need to fix the connection between the lid and the machine?!
Posted on Dec 21, 2007
SOURCE: Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Posted on Aug 29, 2008
  • 91 Answers
SOURCE: Kenmore washer fill problem
make sure you have it on the right settings, or inspect fill hoses cold for clogg
Posted on Jan 04, 2009
  • 351 Answers
SOURCE: My Sears 500 washing machine stops in middle of wash cycle.
timer problem or maybe the lid switch is going bad. Im curious if the motor is getting hot and shutting down... go to whirlpoolpartssurplus.com call .. ask for mark
Posted on Jun 24, 2009
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Kenmore Series 90 top loading washing does not fill with water
    Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
    Aug 23, 2009 | GE WVSR1060A Top Load Washer
    We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
    The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
    Mar 13, 2009 | Washing Machines
    Washing machine
    check pressure switch hose
    Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
    Kenmore "80 Series," model #110.28812790
    Sounds like it may be in you pressure switch sounds like it is stuck on full... like you have a full tub or water..
    the white part with the hose is the pressure switch
    f33c358.jpgck on full... like a full load of water is in the tub
    Oct 19, 2007 | Kenmore 24032\24036 Top Load Washer
    Top loading automatic washing machine not filling
    Aug 31, 2007 | Washing Machines
    Washing Machines Logo
    340 people viewed this question
    Top Washing Machines Experts
