Question about Frigidaire FRT21G4B Top Freezer Refrigerator
Water on the bottom of frige everyday when i wakeup
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
The water dispenser keeps freezing. The Ice Maker is fine. This is happening everyday.; We thaw it out and then is does it again. Fridge is set at 37 and freezer is a 5
if this is a side by side frige the water tube that runs inside freezor door pulls away from insulation causing it to have no insulation between the freezor and the tube alot of then you can thaw one time and there fine. disconnecting the water line at bottom of frige behind toe kickin front and usually is a push in an d release tab connectors or plastic threaded nuts blowing air through can use air compressor not at full blast works great and then once you have it flowing run gallions if possible though to make sure no water deposits no debrie to slow water down to give more chance to freeze oh and if it hasa filter make sure its update and replaced this will help also if still problem persists may need new door they foam insullat these things at the factory cant just move it or put more insulation inside door , door are spending too
Mar 03, 2011 | Kenmore Refrigerators
The freezer has stooped working it is the two door at top with freezer at bottom and ice and water not sure of model number.
check the back of your frige you will see the black roud metal under your frige that is the compressor check the overload of the compressor and also check the wiring diagram at the back of your frige see ther if thers an existing fuse in the wiring diagram.
Aug 11, 2010 | Refrigerators
Have a GE Frige # TBX18SAXPLWW. Large amounts of water collect on inside, bottom of frige. Back wall wet from frige/freezer temp control locate at upper most rear wall of unit. What could problem be?
When in defrost mode, frost is melted and the water is directed to a tray at the rear bottom of the freezer. A tube is connected to the bottom of the tray so the water is sent down the back of the refer to evaporate at the bottom.
The tube gets clogged with gunk, water backs up and freezes. Then, at the next defrost cycle the water has no place to go except into the refer interior.
Unload the freezer, remove the bottom plastic plate, let the ice melt, unclog the tube, put everything back together and you're good to go!
Aug 08, 2010 | GE Refrigerators
Frige/freezer side by side water leaking at bottom freezer door.
your freezer is in defrost for sone reason,how old is it/has it being giving trouble latly.replace or call an engineer,it might be cheaper to replace.adrian,,,,
Jul 13, 2010 | GE Refrigerators
Water is accumulating and freezing on the bottom of the freezer
YOUR DEFROST DRAIN IS PLUGGED, YOU NEED TO REMOVE THEBACK PANNEL THE DE-ICE THE BOTTOM TRAY TO FIND A HOLE, YOU NEED TO CLEAN IT OUT UNTIL YOU CAN RUN WATER THROUGH IT.
Apr 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The icemaker is not getting water from the line, but we are able to get water from the front of the door. what should we be looking at?
The water inlet solenoid has one inlet line and two outlets 1 for icemaker and 1 for water dispenser. Located on the back bottom of frige. Unplug frige. Follow water line to part
Nov 04, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My amana frige leaks at the bottom, it is a bottom freezer frige, I moved it lately because I am laying laminate floor, any solutions?
In your shuffling of the refrigerator you may have knocked the condensate drain away from the pain near the compressor that evaporates the water back into the air inside your home. Or you may have the refrigerator leaning in a way that the water pools up near the condensate drain pipe beginning in the rear of the freezer and has frozen over and causing the water to drain over the condensate collector pan behind the rear wall of the freezer. I have more, Sea Breeze
Oct 16, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
WATER DOES NOT DISPENSE, EVEN THOUGH ICEMAKER WORKS
the way you test that is by going behind the frige and taking the bottom panel and find the water connection as the line connects to the frige there is one line coming to it from the wall and 2 goin out in to the frige 1 goes to the ice maker and the other to the water at the door. disconnect one first and try getting water from the door, one of those lines is going to pas water when you do that, if no one passes water with this test replace that water valve.
Dec 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Frigidaire FRT21G4B Top Freezer Refrigerator Logo
46 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
