Question about Sewing Machines
My machine motor is running but not operating the needle what can i do please
  • 109 Answers
Make sure that your bobbin winder is not on. You don't say what kind of machine you have but usually the post or spindle that you put your bobbin on to wind it up should be pushed to the left to release it. Try that first. If it's an old machine, the belt might be slipping and it might need a belt adjustment by a repairman.
Posted on Sep 10, 2010
About my Baby Lock Serger 750 it is all correctly threaded motor operates but wil not stitch ,this has just occurred on my machine ,I have tried everything .any body help please
Please give us more information on what results are you getting. Is the machine running, the needles stitching, the loopers moving, the knife working? Is it not chaining? Exactly, what is it doing that it shouldn't, or what is it not doing that it should?
If the machine is not working at all, perhaps the door is not latched properly. There is a safety mechanism that will not allow the machine to run unless it is latched.
Jun 11, 2017 | Baby Lock Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
I have a pfaff 261 when the knee pressor is engaged the motor runs but the needle doesn't engage. If i turn the wheel by hand the needle will engage.
First, stop running the motor if the machine is not operating. Most likely the old oil has stuck things together. Continued operation of the motor in such condition could burn up the motor or break a gear.
Pfaff 130 wheel sticks
Will not zigzag or decorative stitches New to these newer plastic style...
Nov 10, 2016 | PfaFF Sewing Machines
Motor running but no stitching is made.
Is the needle going up & down?
If so, remove the thread.
Replace the needle with a brand-new needle.
Clean any lint/debris from the bobbin area, feed dogs, under the needleplate. Oil as recommended in the owner's manual.
Always RAISE the presser foot when threading. Rethread the machine from the beginning and verify the thread path is correct.
Retest the machine.
If it is still not picking up the bobbin thread, there is probably a needle/hook timing issue. Take it for service.
If the needle is not going up & down, something in your machine has seized. Resist the urge to run the motor when the machine parts are not operating. Depending on your machine make/model (if it is mechanical, it probably could use a good service cleaning & oiling), if it is a computerized machine, you should probably take it for professional service.
Jun 04, 2016 | Sewing Machines
Why doesn't it sew?
Check to see if the bobbin case is in correctly. Jamming occurs when something isn't in machine properly. Try taking out the needle & manually turning the hand wheel slowly. It could be just a bent needle too.
Mar 13, 2016 | Baby Lock Sewing Machines
Husqvarna Viking Model 150 sewing machine does not work
Make sure the bobbin winder isnt engaged this can cause the clutch to engage and the motor will run but the machine wont sew
Jul 05, 2009 | Sewing Machines
Sewing machine motor will not run after attempting
Overload Viking:
The machine has a built in overload protector, if your needle can’t penetrate, it may stop the machine from working for a few minutes. Just wait it will reset automatically. Then, try a Sharp needle (denim needle is ideal) and be sure to Never Never reverse sew on heavy fabric, your needle will bend and hit the needle plate, use the FIX button for knotting (it really does work).
Mar 15, 2009 | Husqvarna Designer I
Engine occasionally jams, still able to operate manually
It's been a while since this machines been oiled. try oiling both motor hole and needle operation.
Jan 24, 2009 | Singer Inspiration 4206
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
