Question about John Deere 54" Front Blade Part Catalog 420455 Tractor
I have a Deere LA150 also, and when i took the mower to the shop for this no power up the hills thing they almost called me a liar. I told them that when i start mowing with it it seems to be fine up hills (not impressed) , but when it gets hot after i have been mowing awhile it just won`t move up hills. They said that they took it up the high hill in the back of the shop and it did well, but that is when they first started it up and it wasn`t very hot. I told them wait Until they run it awhile. All it does is sit there and hums. No spinning the wheels or nothing? I think i made a mistake buying this damn thing. My old snapper rider puts this one to shame. I just bought it and it may just meet the sale barn again!
2 Suggested Answers
SOURCE: I have a John Deere LA150 that will not go steep
I have the same problem same year, same model. I changed the drive belt and it still won't go up steep hills that it used to easily climb. I don't see any way to adjust tension and it doesn't cover that in the operator's manual. What did you find out with yours?
Posted on May 24, 2010
Wiring diagram for a LA150
There is no place on line for John Deere wiring schematics
Sep 28, 2016 | John Deere Garden
On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem
"On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem" Okay, what I'm hearing is that "nothing" means the blades-driving PTO won't engage (declutch) when you switch on mower; but then, (say) as you start to dismount the mower (seat) the mower (drive clutch) engages even as the deadman switch (seat switch) kills the engine (and the drive/pto shaft starts to slow down. The key here seems to be that at full engine torque the clutch is unable to remain engaged but, rather, slips so that mower blade inertia (resistence) cannot be overcome...but as engine/pto rotation slows the clutch is able not to slip. First place to consider is the clutch gap which is probably to0 large (possibly from wear and tear, possibly not). So check specs and how-to from manual or factory and reset the pto drive clutch gap...not hard to do. If clutch gap is not the problem then most likely rehab or replacement of the clutch assy will be needed...is the mower has many years use sufficient to wear out the clutch. Another possiblity is an electic (wring/switching/grounding) problem involving mower and deadman switches.
Aug 19, 2014 | Garden
My john deere 316 loses power going up hills and when I have the mower pot on
Sounds very much like a fuel issue, i.e., starving for fuel. Check the fuel filter and replace.
Aug 04, 2014 | John Deere 300 / 316 Hydrostatic Tractors...
Eletric PTO is not working
The PTO draws a pretty good current, so a weak or loose contact in the switch, or in the connections on the back of the switch, could cause this overheating. But it could also happen if the PTO clutch itself or the wiring to it has a short. If the mower's still under warranty, get the dealer to diagnose and fix it. If not, then I'd measure the resistance of the PTO clutch - should be about 2 ohms - and make sure the wiring to it isn't shorted. If all that is OK, then just replace the PTO switch and any melted connectors and wiring. Good luck!
Jul 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
May 01, 2010 | John Deere 54" Front Blade Part Catalog...
John Deere 54" Front Blade Part Catalog 420455 Tractor Logo
122 people viewed this question
Top John Toys Experts
Vernon Taylor
Adam Fjeld
Adam Fjeld
Are you a John Toy Expert? Answer questions, earn points and help others
