Question about Dishwashers
I have a Kenmore Ultra wash 665 model # 16831that the control panel is locked, when i push the no heat dry button to unlock the control panel the light blinks 2 or 3 times but stays locked. Solution?
  • sneiufi Sep 10, 2010
    worked like a charm...thanks so much!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve this issue try to press and hold the NO HEAT DRY/Air DRY button for 15-20 seconds, if this won’t resolve the issue then you’ll have to replace the control panel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 10, 2010
Old dishwasher, lock on light blinks all time
Is this a Kenmore? If so here is Searspartsdirect. User and installation manuals, parts diagrams and parts lists and repair help.
KENMORE Dishwasher Parts Model 66515817990
Oct 26, 2014 | Kenmore Dishwashers
Kenmore ultra wash model 665 has lock on light. Does not respond to no heat dry four seconds.
Press and hold the heated dry button for 5 seconds and see if that will unlock the control panel. If not then try to flip the circuit breaker off for a minute and see if it resets. If nothing resets, then you just need to replace the control board because it's shorted.
Good luck.
Draven at www.ApplianceRepairLesson.com
Mar 04, 2011 | Kenmore Dishwashers
How can I get my lock on light off and turn my ultra dish washer on all buttons are disabled it is kenmore 665 15819
If the model number is correct, press and hold the "NO HEAT DRY" button for 4 seconds to lock or unlock the controls.
Aug 23, 2010 | Kenmore 15899 Built-in Dishwasher
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
My kenmore dishwasher 665-15817 has a blinking ''Lock On'' button
- To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Jun 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore ultra wash dishwasher
More than likely it is a shorted key. replace the touch panel.
Dec 04, 2008 | Kenmore Dishwashers
Dishwasher Problem
According to my ultra wash dishwasher you have to hold the no heat dry button for 4 seconds and that is how you lock and unlock the control panel
Jun 30, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Feb 02, 2008 | Dishwashers
Dishwashers Logo
113 people viewed this question
Top Dishwashers Experts
