I can't find our instruction booklet and I need to change the black ink cartridge
  • 6,831 Answers
Hello
OK, if you supply me with the model and brand of the printer, i will be able to give you a link where you will be able to download the manual.
Let me know.
Kind regards
Andrea
Posted on Sep 10, 2010
Advent resetting ink levels
Hi There
Your all-in-one printer is designed to stop printing before quality is compromised. Make sure you always use KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to the KODAK Store.
To resolve the error, replace the black ink cartridge with a new cartridge:
  1. Turn on your printer.
  2. Open the access door. For printers with LCDs, follow the instructions on the LCD screen.
    NOTE: For ESP 3250 and ESP 5250 all-in-one printers, if the ink cartridges don't move to the center when you follow the instructions on the LCD screen, see Printhead and ink cartridges do not move to center with access door open.
  3. When the printhead stops moving, pinch the latch on the black ink cartridge and lift it out of the printhead.
  4. Remove the new black ink cartridge from its bag.
  5. Remove the protective cap from the black ink cartridge.
    CAUTION: Insert the ink cartridge immediately to prevent the printhead from drying out.
  6. Insert the black ink cartridge into the printhead.
  7. Press down on the tab until you hear a click.
  8. Close the access door. For printers with LCDs, follow the instructions on the LCD screen.
    NOTE: For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
If the error continues, upgrade the firmware for your printer:
  1. Press the Cancel button on your printer to clear the error message. (If the error does not clear, contact us.)
  2. Upgrade the firmware for your printer:
    1. Locate and select the firmware download for your printer.
    2. Follow the instructions to install the firmware.
  3. If the error continues, contact us.
Support Link :
Mar 29, 2012 | Office Equipment & Supplies
How do I install the printer cartrige? I do not have the booklet...
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    How do you change the black cartridge in the printer epson stylus nx115
    Here is the Link showing instructions below. If you find this helpful, pls rate me.
    http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
    Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
    If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
    If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
    Warning:
    Keep ink cartridges out of the reach of children and do not drink the ink.
    Note:
    If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
    You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
    Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
    replace them to prevent the print head nozzles from drying out.
    When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
    Follow the instructions in these sections to check and replace your ink cartridges:
    Check Cartridge Status
    Purchase Epson Cartridges
    Replace Cartridges Using a Printer Software Utility
    Remove and Install Cartridges
    pls rate me. Thanks and Good Luck...
    Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
    Refill instructions for a Dell Series 5 ink
    Cartridge World stores can refill these cartridges for you.
    Oct 23, 2009 | Dell 924 All-in-One InkJet Printer
    I want to change my black ink cartridge and never do that !
    Here you go - detailed instructions on how to change the ink - link
    Dec 08, 2008 | HP Officejet 5610 All-In-One InkJet...
    Changing ink cartridge on the HP Photosmart C3180 all in one
    The Basics manual from HP:
    http://h10032.www1.hp.com/ctg/Manual/c00694908.pdf
    Check out page 17 of the Basics manual for detailed instruction on replacing the cartridges.
    Make sure the HP All-in-One is on.
    Caution If the HP All-in-One is off when you open the print cartridge door
    to access the print cartridges, the HP All-in-One will not release the
    cartridges for changing. You might damage the HP All-in-One if the print
    cartridges are not docked safely when you try to remove them.
    2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
    3. Open the print cartridge door.
    The print carriage moves to the far right side of the HP All-in-One.
    4. Wait until the print carriage is idle and silent, and then lightly press down on a
    print cartridge to release it.
    If you are replacing the tri-color print cartridge, remove the print cartridge from the
    slot on the left.
    If you are replacing the black or photo print cartridge, remove the print cartridge
    from the slot on the right.
    1 Print cartridge slot for the tri-color print cartridge
    2 Print cartridge slot for the black and photo print cartridges
    5. Pull the print cartridge toward you out of its slot.
    6. If you are removing the black print cartridge in order to install the photo print
    cartridge, store the black print cartridge in the print cartridge protector or an
    airtight plastic container.
    If you are removing the print cartridge because it is low or out of ink, recycle the
    print cartridge.
    7. Remove the new print cartridge from its packaging and, being careful to touch
    only the black plastic, gently remove the plastic tape by using the pink pull tab.
    1 Copper-colored contacts
    2 Plastic tape with pink pull tab (must be removed before installing)
    3 Ink nozzles under tape
    Caution Do not touch the copper-colored contacts or ink nozzles.
    Touching these parts can result in clogs, ink failure, and bad electrical
    connections.
    8. Slide the new print cartridge forward into the empty slot. Then gently push on the
    upper part of the print cartridge forward until it clicks into the socket.
    If you are installing the tri-color print cartridge, slide it into the left slot.
    If you are installing a black or photo print cartridge, slide it into the right slot.
    9. Close the print cartridge door.
    If you installed a new print cartridge, the HP All-in-One prints a print cartridge
    alignment sheet.
    Note If you have colored paper loaded in the input tray when you align
    the print cartridges, the alignment will fail. Load unused plain white paper
    into the input tray, and then try the alignment again.
    If the alignment fails again, you might have a defective sensor or print
    cartridge. Contact HP Support. Go to www.hp.com/support. If prompted,
    choose your country/region, and then click Contact HP for information on
    calling for technical support.
    Nov 25, 2008 | HP Photosmart C3180 All-In-One InkJet...
    Dell 926 Printer ink refill instructions
    I don't have a Dell but we have Lexmarks which use similar cartridges. I'm guessing your color and black has a flat top. Your printer should be using a 2 cartridge system and most likely w/ 4 colors. Black, Cyan, Magenta and Yellow. The Black cartridge is a single color cartridge. The CMY (short for Cyan,Magenta,Yellow) is in another cartridge. If you don't know which one, get a paper tower and dab the bottom of the cartridge near the nozzles which are usual silver in color. If you have the color you now need a very thin needle to fit those very small holes. If your needle wont fit then you will have to enlarge the holes. To refill,you really will enlarge it anyway to inject the syringe needles in. Stick the needle into the hole as deep as you can and stop just before you hit bottom. Just approximate the height of the cartridge to the needle. When you take the needle out, use a paper towel or toilet paper to wipe off the ink. What you wipe off will be the color of that chamber. You just need to do one more on any of the 2 remaining holes. Label as you go so you know what color it is. Don't do mental gymnastics. One mistake means you either print w/wrong colors or buy a new cartridge. I'm not familiar w/ the cartridge so I'm guessing on the color you should put between 1-2ml of ink per color. On the black maybe 5-8ml. This is to be on the safe side. Don't overfill it. There's no guarantee your cartridge will print, cuz manual refills are not as good as those done on a machine. If it works you may be able to refill another 2-3 times. Manual refilling is a gamble. Just ink the ink in very slowly and be patient. take about 15-20 seconds to inject 1 ml. Hope this helps.
    Nov 13, 2008 | Dell 926 All-In-One InkJet Printer
    Error check ink cartridge
    Hi ,
    As per the information provided by you it seems to be a hardware issue however u cvan try these steps .
    Steps >
    Take out the ink cartridges from the printer > without turning off the printer unplug the power cord > press # and 6 key together , now without releasing the keys plug in the power cord .
    keep on holding the keys down until the machine turns off automatically .
    after the unit turns on again it would do the allignment give a msg for insert ink cartridges . insert the cartridges at that time . and see how it works out .
    Thanks
    MAC.
    May 24, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    Changing ink for X1290
    The printer needs to be on in order to change the cartridges. When you open the lid the cartridges should move into view.
    Jan 15, 2008 | Lexmark X1270 All-In-One InkJet Printer
    15 people viewed this question
    k24674
