Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
My washing machine works fine all the way to the spin cycle when it starts to make a weird buzzing noise. It's not the balance or the clothes inside, the noise comes from in the back somewhere
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
Based on what you`ve described, it sounds like perhaps there is an obstruction in the pump...or perhaps the pump is indeed seized/failed.
I would first check the pump for obstructions.
**Unplug the washer or turn off your breaker before servicing the washer...safety first**
To clean the pump on your washer, If you direct your attention to the bottom right side of your Bosch you'll see a small round cover like so...
With the aid of a small screw driver, knitting needle, or anything small enough to fit in the small hole in this cover...
It will push in a tab, it doesn't take much force.
Rotate the hole (clockwise) to 6'oclock and it should come free, the edges are very sharp so be careful.
Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a green or red ring attached to a metal clip on the pump, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out. There is potential for a lot of water...even if the washer looks empty.
Now pull out the trap/filter and visually inspect the inside of the pump as well aMy washing machine works fine - cba5b21.jpgr/trap.
That is how you gain access to and clear the filter on your Bosch washer.
If this was the problem, awesome. If not let me know and I`ll try and help further.
Hope you found this helpful. If so please take a moment to write a short testimony and leave a rating.
Thank you for choosing FixYa, good luck.
Regards,
Macmarkus :)
Posted on Sep 10, 2010
    Problem Solver:
  • 19 Answers
Time for a repair/replacement
Posted on Dec 12, 2010
A ge top load washer first began by making a buzzing noise instead of spinning. Now it doesn't spin as fast as before or just wont spin. Jeans wrapped around the agitator shouldn't damage the spin?
the agitator spins with the tub so clothes wrapped around the agitator will have no effect on the spin other than a balance problem
The hum and failure to start spinning may be attributed to a failed (failing ) start run capacitor or program board not moving on properly
As the start /run capacitor is for the motor and if it start the wash cycle ok but after that cycle ( around 30-40 minutes) it may be too hot to restart the motor for the spin
I suggest that a technician be called in to get a proper diagnosis and a quote
Apr 14, 2016 | GE Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Clothes too damp after spin cycle
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Washing Machines
Bosch washer won't spin with wet clothes
I am not sure if Bosch has a "load sensing" sensor, but I would start there else you may have a motor issue, or bad capacitor on your motor.
Aug 03, 2012 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My washer makes alound grindin noise wen trying to empty
1) most Noises coming from washing machines coming during the cycles of SPIN .Clothes load can be un-balance. Stop the machine and balance the clothes.Start again, and repeat the step if necessary.
God bless you
Jun 28, 2012 | Washing Machines
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Very noisy when on spin. The machine seem to be balanced however the noise on spn is like a jet taking off. it gets louder as the spinning speed increases.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Mar 28, 2010 | Maytag Washing Machines
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Washing machine clothes dry
Is the belt broke? Have you checked during the wash cycle if it is agitating.
Mar 28, 2009 | Washing Machines
It makes buzzing noise and doesnt work
click the link http://www.repairclinic.com/0088_11_1.asp#Level1_5
Dec 11, 2008 | Kenmore 24902 Top Load Washer
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
262 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
