Question about Bosch Washing Machines
Bosch maxx clasic front loader Wkm41 the control panel has just died. what can I do to fix this?
I had the same issue this morning. I turned on the washing machine change a few settings, but didn't want these setting so i turned off and on again. When i turned it back on the panel was blank, but what had happen was the spin button was stuck in. Once i free the button the panel came back on.
Regards
Posted on Feb 05, 2011
Need a manual for bosch front loader wkm41
http://laundry.manualsonline.com/manuals/mfg/bosch/800_series.html . That should be the manual for the bosch wkm41. If not get back to me and i'll take another look. Also the bosch website has manuals searched by serial number if you get too stuck.
Dec 28, 2014 | Bosch Washing Machines
My Bosch Maxx Clasic says E5 - what does this mean?
please see the next step:
1) turn off the machine, and inspect the water connections
2)This error occurs if the appliance does not take in water or does not do so correctly. Make sure the water intake tap is turned on.3) Refer you instruction manual for aditional idea. if you do not have download from www. retrevo.com or from Bosch.
God bless you
May 16, 2012 | Bosch WFL 2062 Front Load Washer
The softner tray on my front loader Maxx Clasic BOSCH does not drain - it fills with water which, together with softener, remains in the tray. Heeeeelp!
Hello, W/D here.
Remove the tray, and clean the tubes on the bottom side of the dispensers and the mating tubes on the machine. This should put you right.
Best regards, --W/D--
Feb 24, 2011 | Bosch Washing Machines
Hi, my Bosch maxx 900 front loader washer was in the process of doing a load when a really loud bang happened..now it won't spin..makes all the right noises, but barrel won't move. Took off back panel and...
If you rotate the pulley on the back of the drum does it rotate the drum? i have seen these snap the back of the drum off. also they can have issues with the controller board for the motors which would require a technician to determine.
Oct 24, 2010 | Bosch Washing Machines
Replacing the door seal of a bosch maxx 1000
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Aug 26, 2010 | Bosch Washing Machines
How do I replace the door seal to a Bosch Front loader washer Maxx Classic WAE18060AU?
To change the seal the easiest way is to take the front of the appliance off. Remove the kick plate at bottom and you will see some screws holding the front panel on remove these Then open door and remove the screws holding the door lock on and unlip the seal by releasing the clamp on the front. The front should now lift off, if it doesnt then pull out the soap drawer and behind that at the bottom of the drawer is a screw holding the front on remove this then push the front panel down then it will lift off You can now take the clamp holding the seal to the tub off. Fit the new seal, fit the clamp to the seal and tub. From here, rebuilding is the reverse of the strip down.
Feb 18, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Front Loader Washer Door Hinge broken
There are a couple of sites you can try.
WWW.ESPARES.CO.UK/BOSCH
WWW.4BOSCH.CO.UK/SPARES
Please rate my solution.
Thankyou
Feb 06, 2010 | Bosch Washing Machines
I have a bosch maxx Wlf1600 front loader washing machine
This will require a replacement door lock,easy replacement & part very cheap
Jun 08, 2009 | Audiovox Bosch 718 World Cellular Phone
Washing Machines Logo
469 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
