Question about GE (PSS26MSRSS) Side by Side Refrigerator
I HAVE A PDS22MHRBB BOTTOM FREEZER REFRIG, THE FREEZER KEEPS FREEZING UP AND FRIG NOT COOLING, I HAVE CHANGED THE MAIN BOARD, AND THE HEATER AND STILL NOT FIXED, ANY OTHER IDEAS?
  • 121 Answers
There are two more things that can cause this problem the freezer thermistor and the defrost thermostat. The thermistor is a lot more common than the thermostat but both can cause the problem. These two pages will help.
http://www.appliance-repair-it.com/refrigerator-thermistor.html
http://appliance-repair-it.com/GE-refrigerator-repair.html
Posted on Sep 10, 2010
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
My coils are freezing . i have replaced the heating elament and timer and its still freezing.
What timer did you replace ? Your refrig uses a control board , not a timer .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a defrost heater WR51X10055 not working or the defrost thermostat ( pt. number WR50X10068 ) not working . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off / on .
May 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig frosted up and quit cooling
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off at selected temp .
Apr 19, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE S/S GSS25JETA BB freezing up on back wall of freezer & all cooling stops. It happened 2 months ago, then somehow starting working again after I scraped ice off back wall. Froze up again this week....
This is a little work , but it will save you a service call , parts up-pricing , and labor .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board ( you already know , since you changed it ) . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and when to cycle off .
Dec 14, 2009 | General Electric GSS25JET Side by Side...
Top of freezer not freezing and refrigerator not
Dirty coils not likely the problem .
Open the freezer door .( Behind the back panel ( inside the freezer ) is the evaporator fan motor . ) Push in on the freezer door switch , and listen for the fan to come on . Sometimes , the fan will stay on , even if the door is open . Do you hear the fan ? If not , then the main control board , behind the refrig , behind an 8 " X 10 " panel , is probably bad . If you do hear the fan , then you are having a defrost problem . Pull the refrig out and remove the 8 " x 10 " panel .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and , when to cycle off , due to set temperature reached .
Dec 10, 2009 | GE HSS22GFT Side by Side Refrigerator
My refrigerator the evaporator keep freezing , i had clean out the ice ,but after 2 , 3 week it freezing again , can please let me know . my refrigerator model-gsh25jstass
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board ( you already know , since you changed it ) . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater ( pt. number WR51X10055 ) . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fan cycling low and high
The freezer fan slows down due to the refrigerator section being at the desired setting but the freezer section still needing coolant . If the refrig section needed more coolant , the fan would speed up , forcing more air into the refrig section .
After replacing the heater , it could be in the defrost cycle . The thermistors tell the main control board , " hey , we're freezing , turn on some heat " , in which the heater comes on and defrosts the coils , until behind the rear freezer panel , can get up to 140 degrees . As it gets this hot , the frozen food in the freezer , is what keeps the freezer cold . After defrost , the fan comes on and blows the residual heat into the refrig sectio , until the coils get cold again . So , if the refrig section warms up temporarily , it's normal .
Sep 06, 2009 | GE Refrigerators
My GE side by side Model # GSS20IEPA has frost on
Is the fan in the freezer working ? May have to press the light switch in to test . If not , main control board is probably bad . not the fan moter . Pull refrigerator out and remove the small 10"X13" metal cover . Unplug refrig first . Then remove the blue plug with 3 wires attached to it . The wire sequence on the plug looks like this : wire 1,wire 2,space wire 3.
Use an insulated jumper wire with both ends stripped and insert one end into wire 2 and the other into wire 3 . Plug refrig back in and look in freezer at the bottom . If the heater and defrost thermostat are good , the a red glow should appear . No red glow , either bimetal or heater is bad . Most likely heater pt# WR51X10101 . Do not forget to reinstall the blue plug with refrig unplugged or could cause main board dammage .
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our ge refrig runs constantly,freezer is freezing but the refrig is not cooling. I cleaned the dust and dirt out of the bottom and back of refrig.
See if the fan in side the frig is working It mite be on the freezer side If the fan is not working it will not blow the cold air in to the frig side
Jul 12, 2009 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
108 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
