Question about Magic Chef CTB1821AR Top Freezer Refrigerator
Freezer icing up - Magic Chef CTB1821AR Top Freezer Refrigerator
  • Magic Chef Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Freezer stays cold. Why is fridge part warm?
if freezer gets iced up the fan designed to pass cold air from the freezer to the fridge stops working. The freezer is meant to go into a defrost mode when its trtansducer senses too much ice. If the transducer goes fault the ice builds up. Some fridges use a timer to work this out so it could be a timer fault. Talk to a service man about how much ice the freezer should have for them to sucessfully diagnose the fault. Too much ice may prevent the service man from working out if temperature sensor is working and no ice can prevent him from testing sensor. To get rid of ice you have to trun off the power to the fridge and let it melt.
BEWARE remove food to another freezer and fridge to prevent food going off or getting food poisioning
Sep 17, 2015 | Estate TT14DKXKQ Top Freezer Refrigerator
Electrolux american fridge freezer cooling problem
There is a defrost timer on the unit. It is supposed to come on and melt the ice that forms on the coils in the evaporator. IF you get a lot of ice built up or something is wrong with the timer, it wont melt the ice or it wont come back on to cool the unit.
Dec 09, 2013 | Electrolux Refrigerators
Kenmore upright freezer. Ice cream soft. Food is cold. HELP!
Ice cream has to be colder than 0 degrees C /32 degrees F. You need a cheap thermometer If your Ice maker Ice is not sweating in the bin, -10 degrees F ice stops sweating. you need not to sweat the freezer untill your cheap freezer thermometer can be compared to -10 degrees F
Nov 29, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Ice maker will only make crushed ice and no cubes, what could be the problem
Open the freezer door.
Pull the ice bin forward about 3 inches.
Push the ice bin to the rear of the freezer until it seats and locks in place.
Then try to dispense cubes.
The ice bin can become dislodged from its locked position and the crushed ice solenoid activates automatically.
Sep 17, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
My GE Profile Artica ice maker is making ice, but when I open my freezer, there are icicles from the ice compartment one the food below the ice maker and dripping down the inside of the freezer. The ice...
Hi!!
The Ice Maker and the Freezer/Fridge part of the unit work separate, that's why you get the ice made but the freezer can't keep it frozen.
Most likely the condenser, located in the back of the freezer is all frozen and covered with ice pluggin up the air ducts to the fridge, preventing it from cooling.
One quick solution will be unplugging the refrigerator and allowing it to defrost on it’s own or remove the freezer's back panel and using a heat gun or hair dryer to melt the ice, this will take about 20 to 30 min..
There are various reasons this type of problem:
The temp. controls are not set properly. Set controls according to manufacturer recomendation.
The small fan in the freezer is not working,
The defros timer is not working or,
The defrost heater coil is busted.
Once the ice is melted, plug unit back in and check for unit reactions. You should be able to hear the freezer fan working. Also, you'll hear about 4 to 6 times a day the defrost heater melting the ice in the back of the freezer, if NOT, check heater coil for continuity.
Don't forget to rate this post. Good Luck.
Jun 07, 2010 | GE Profile Arctica Stainless Steel Top...
Freezer is not defrosting
1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
3. Unplug the unit and leave the freezer door open.
4. Let the freezer defrost overnight or for at least eight hours.
5. Use the towels to wipe up the melted ice.
6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Freezer not cold enough/ice maker not working
Check the coils in the freezer to see if they are blocked with ice.
May 01, 2009 | Frigidaire 11.6 cu. ft. / 328 liter...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Magic Chef CTB1821AR Top Freezer Refrigerator Logo
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
