Question about AEG Lavamat Lavalogic 1600 Front Load Washer
Where can i find a whitewestinghouse LM0652 user manual
Westinghouse dryer LD505E is to be mounted on a brick wall ,what size rawlplugs & screws are needed .I bought the wall bracket mounting kit
that unit does not have wall mounting information its user manual
or a wall mount bracket supplied with that dryer
its a 5KG dryer by the looks of it
thats means its load a with 5kgs of wet clothes on the floor
suggest to me its no meant to be wall mounted
http://laundry.manualsonline.com/manuals/mfg/whitewestinghouse/whitewestinghouse_dryer.html?p=7
wall mount kit might be say suit most dryers
you have to go by common sense
use bigger mountings and fixings that you think it needs
has to hold up on the wall
this much weight
the all up wet weight of clothes
the dryer dry weight empty
and steady any vibration with the rotation on full load
into wood walls depends on the thickness of wood
if into dry wall ...need to hit the wall studs centre
I would not try it
if going into brick concrete ...hammer drill in and . ranset bolts
Sep 16, 2016 | Dryers
Clean lint filter on wwx223rbw2
http://laundry.manualsonline.com/manuals/mfg/whitewestinghouse/whitewestinghouse_washer_product_list.html
Jan 24, 2013 | Westinghouse Washing Machines
I need the code acces for my 6 in 1 universal remote control please. my nexxtech remote control is for whitewestinghouse tv.
http://www.universalremote.com/resources/pdfs/Manual_RF30.pdf
There you go. Everything in there.
Mar 29, 2011 | Universal RF30 Remote Control
WHITE-WESTINGHOUSE TV/VCR COMBO NEED CODE
The code for the TV is 0623 but to use the TV/VCR button to change mode from line to TV the code is one of the following 0179, 0451, 0463, 0624 or 0278. The 0623 only activates the menu but doesn´t let you change Air/Cable mode without first changing the Line/TV mode by pressing the TV/VCR or Line input button on your universalk remote with one of the other codes.
Oct 28, 2007 | Zenith ZN110 Remote Control
VCR Codes
ilipo87';u/i;ikiiio 97pomjn b mii899999999 o
Oct 11, 2007 | Philips PM-DVR8 Remote Control
AEG Lavamat Lavalogic 1600 Front Load Washer Logo
35 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
