Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Need to find IP Address on bizhub C250 - Konica Minolta bizhub C250 All-In-One Laser Printer
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
SOURCE: getting the ip address
To print out machine current ip address, go to utilities, user setting, printer setting, print reports, configuration.
Posted on Mar 23, 2008
SOURCE: Transfer unit Bizhub C250
reset life of actual transfer
Posted on Feb 14, 2009
Geekman
  • 32281 Answers
SOURCE: I am trying to install my bizhub c250 through
What you have done should have worked.
You may need to enter the IP address into the printer using the printer console not via the computer printer properties.
If it still does not work check the IP address range of your network card, the printer's Ip address needs to be in the same range, ie the first group of numbers must be the same, only the last group of numbers are different.
You may need to use a LAN hub with normal LAN cables and not a crossover cable.
Posted on Jul 23, 2010
  • 20 Answers
SOURCE: how do I find out
I found complete networking instructions in the first few pages of this PDF:
http://filedb.experts-exchange.com/incoming/2009/04_w15/125026/AD-NDS-SMB-20userauthentication-.pdf
Posted on Apr 20, 2011
Testimonial: "Thank you for the quick response."
Remoteing to a bizhub printer using internet explore8
Open internet explorer 8 by simply double clicking on it.Now in address bar, enter/type the IP address of your photocopier machine.After entering the IP address press "ENTER"Web connection page will appear.Thats all..
Jan 06, 2012 | Konica Minolta bizhub C250 All-In-One...
How do I change the netwok IP address on the c250
Hi CTF3,
To change the IP address of your Bizhub C250:
Push UTILITY/COUNTER
ADMINISTRATOR SETTINGS
put in the password, should be 12345678 unless someone has changed it.
NETWORK SETTINGS
TCP/IP
I think you NEXT few the next screen and you should see the IP address which is currently assigned to the device.
Hope that helps
Kind regards
M-Press.biz
Feb 21, 2011 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 won't print or scan. Checked IP address on bizhub, and it is as always (192.168.1.100). Reinstalled Print Drivers (PCL6, Ver 2.53) but didn't change. Ping gets no response....
Your first priority should be to put it on the network , for this u should give the printer the IP 192.168.2.XX where XX varies from 4-99 . Please make sure that no other device should have the same IP which u are assigning it to the printer and and try to ping on the network.
Jan 31, 2011 | Konica Minolta bizhub C250 All-In-One...
I am trying to install my bizhub c250 through network cross cable with my computer. I adopted almost all the instuctions available for the configuration of the same but could not get a print through...
Jul 23, 2010 | Office Equipment & Supplies
Bizhub 250 All-In-One Laser Printer: My bizhub c250 is going through a hub to a router....
Type in the ip address of the copier in your web browser. You should be able to log on to the web image monitor and even print a test page. If so you are 90% of the way there. Now go back to the printer setup screen in windows and click on the "port" tab then on configure port. Make sure the port ip address is the same as the copier and make sure the port number is 9100. Keep in mind that the ip address of the copier needs to match the ip address of your network for the first 3 sets of numbers. So if your network ip is 192.168.50.50 the copier would need to have an ip address of 192.168.50.xx
Good Luck and Thank You for using Fixya
May 17, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta 250 Bizhub scanning Operations
You need to create a "one-touch"
This can be done in the Admin Screen without having to enter a code.
Better yet is to just yype the IP address into your browser and create them there.
The copier will need an email address in order to send them and you may need to log out and then back into the 250 as an "Admin".
Jul 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Scanning issue
Type in copier IP address in web browser. Go to scan, program and add new.
Mar 12, 2008 | Konica Minolta bizhub C250 All-In-One...
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
BIZhub C250
try the web based configuration
Apr 18, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
1,461 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
