I have an Iball mouse usb type. Suddenly it has stopped selecting unless I press shift. Sometimes it selects erratically too. It has also become very fast although I have put the opening speed of folders as slowest. for example if I click once to open the browser windows then 5 to 10 windows will open simultaneously.
  • 3,083 Answers
Try going into Control Panel, then get to the Hardware folder, pick Mouse, and go to Driver, and update the driver- it could be corrupt.
It sounds like a corrupt driver, and that's where we should start. Of course, the mouse could be bad. I see you have a mac, and I've never had one of those, but get to the folder that has your mouse and reinstall the driver, if you have that option. Hope this helps.
Posted on Sep 10, 2010
My imicro mouse was working properly then suddenly it stopped, changed batteries, restarted PC, pressed the reset button at the bottom of the mouse but won't work anymore.what else can i do aside from...
you might have to uninstall the mouse and its drivers then restart your computer then reinstall the mouse and its drivers
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have the options update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
Feb 19, 2011 | Aashima iMicro MO-16SBL Mouse
My blackberry torch just suddenly stop working the screen after 7days from my purchase date the screen turned to black while i can see the keyboard has lights.
It may be locked up. Take the battery out for about a minute and then put it back in. If it boots up and works you are fixed. If that doesn't work there are other resets:
Soft Reset
Press ALT + RIGHT SHIFT(CAP) + DELETE.
Double-Soft Reset
Press ALT + RIGHT SHIFT(CAP) + DELETE . The screen will go blank for a few seconds. When the screen comes back on, immediately press ALT + RIGHT SHIFT(CAP) + DELETE again.
If none of that works a data wipe and reset is indicated:
1. From the home screen, press the Menu button.
2. Select Options.
3. Select Security Options.
4. Select Security Wipe.
5. Check the items you wish to wipe.
6. Type blackberry in the box.
7. Select Wipe.
Follow the instructions.
If that doesn't work its fried and I hope its still under warranty
Jan 27, 2011 | RIM BlackBerry Torch Cell Phone
Logitech with invisible optic After replacing battery, mouse became very erratic, sometimes moving, sometimes not. When "reset" is pushed it works for awhile then becomes erratic again.
Could be a bad batteries. I only use Duracell in mine, however, mine is a Microsoft. Also, check the manufacturers website for driver updates.
Nov 11, 2010 | Logitech Cordless Mouse
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
My mouse suddenly stopped operating during uploading of photos from a Kodak camera
Is there a blinking light on the receiver? Many times the mouse doesn't work because it has become un-sync'd with the USB receiver. Check on the sides or bottom of the mouse and see if there is a small button. Press it and try the mouse again. Let me know if this helps!
Apr 18, 2010 | GE 97985 Mouse
Using Saitek Mouse Model M 188 USB on Toshiba Laptop running Vista Home Basic and with a AOC external monitor. Mouse very erratic, can this be remedied?
from controle panel select Printers and Other Hardware then mouse
if you go to the 3rd tab you can select a pointer speed
Jul 20, 2009 | Apple Mouse
Logitech Optical Mouse M-UV96 Malfunctioning
this is factory problem. replace the mouse please. mine works fine.
rate this
Apr 06, 2009 | Computers & Internet
DELL Dimension E510-mouse erratic, usb pop ups
Did you check to see if your type mouse is compatible with your unit and your operating system? (XP or Vista?)
Jan 05, 2009 | Microsoft WHEEL OPT USB PS2 3 Button...
Left click of my logitech cordless optical mouse not works properly
try to set on your MOUSE, here:
start-control-panel-mouse folder
hope this can help. :)
May 16, 2008 | Logitech Wheel Mouse Optical
Computers & Internet Logo
259 people viewed this question
David Payne
David Payne
