Question about HP OfficeJet 7310 All-In-One InkJet Printer
A lightning surge hit my HP7310 all-in-one, is itrepairable?
  • 3,083 Answers
It all depends on what was damaged. Unfortunately, there is nothing that can totally protect against lightning since it's high voltage and varying current and too fast. One has to get into the printer and try to determine what damage has been done.
Often, it is not feasible to fix, since extensive damage can be done to the delicate ICs.
Good luck, but this will not be easy to fix, unless you get lucky and have just power supply damage (which is possible).
Posted on Sep 10, 2010
TV no power.Cable hit by lightning.
if didnt have a surge protector and unit took a lightning hit more than likely unit totally fried
Jul 31, 2016 | Televison & Video
Got hit by lightning and won't turn on. Power source is good. Need to find out how to take it apart.
Most of the time after an appliance has been hit by lightning, it is toast. In the case of a printer you can probably buy a new one for the cost of the replacement part. Next time make sure you also purchase a surge protector to plug your computer and printer into and then you will be protected from lightning strikes.
Sep 29, 2015 | HP Officejet 6700 Premium E-All-In-One...
Is the module of lg tv 32ld330-mb affected when theres a lighting strike???is there a chance to be fix??
The damage from a lightning strike tends to be random. Sometimes it's minor, and only a few parts are affected. Other times, many parts are ruined, or destined to fail soon as a result of the current surge.
If the strike came over the power line, the input surge protectors in the power supply should be replaced, even if they look good. It would be prudent to replace the entire power supply. If you had the set plugged into an external surge protector, that should have taken most of the hit and should also be replaced. (Some surge protector manufacturers will pay up to a certain amount for repair or replacement of equipment plugged into their products if it is damaged by lightning.)
If the lightning came over an unprotected input cable, fixing the set would be a gamble. You could end up changing a lot of modules, beginning with the main board.
Jan 30, 2015 | LG Televison & Video
Panasonic Home Theater System ....No power
Likely a power surge hit your house while away. This happens when power turns back on or lightning hits close to your house. If insured, call insurance company about it. You may be covered for replacement or have deductible applied. Small appliances like this are most susceptible to power surge. There is not enough protection designed in.. The best protection is surge module on main breaker panel or buy a protected power strip to protect high value electronics.
Apr 16, 2014 | Panasonic Audio Players & Recorders
My window unit got hit by lightning and blew the plug right out of the wall, although it had a surge protector on it- it does not work now- any ideas on what I could try to fix it like a new fuse or...
As you saw a surge protector doesn't stand a chance against lightning!!!
The unit is toast... turn it into homeowners and buy a new one...
heatman101
Jul 12, 2011 | GE Heating & Cooling
My mr coffee Iced tea maker has been working great for a year. Tonight it tripped a ground fault breaker, and only started a tea cycle. I reset the breaker and the machine squirted once then started to...
we had one like this and we suspect a power surge damaged it. it worked fine one night, but we had a lightning storm that night and we think lightning hit out power pole and fried several of our appliances. the tea maker would come on but like you described it seems to forget what its doing. consider the possibility that a power surge got it (doesn't have to be lightning, several things can cause a surge)
Aug 12, 2010 | Mr. Coffee Iced Tea Maker TM1S
My sister in Charlotte, NC had a couple of seconds power outage, her processor, modem, monitor, tv and phone were connected to outlet thru a surge protector. All work except processor. Is there a reset for...
No reset for that processsor.. ALL Surge protectors are not guaranted for lightning strikes. Does she know if lightning hit the line that services her home?
Jul 13, 2010 | HP Pavilion a1540n PC Desktop
Lightning Surge, RCA 32V432T, will not power up
Throw TV AWAY,these tvs had alot of problems without lighting hitting them,It probably played out FBT flyback transfomer CK hori out put Transistor if shorted replace FBT also.
Aug 06, 2009 | RCA D52W19 52" Rear Projection Television
After my house was it by lightning my Onkyo
If your receiver was connected to any power source and that power source was not a surge protector strip there may be damage to the receiver as lighting travels. Another thing to consider is the fact that many people will put their equipment on surge protectors but the cable is still connected to the TV etc...This is just another avenue for the lightning to get into the home and blow up your system. I always disconnect any cable from my computer and TV. The power source from the wall is also unplugged when there is a storm just to be sure. Surge protectors are limited in their use as well. I don't believe they can take too many lightning hits. It is best to change them out.
Jul 18, 2009 | Onkyo HTR500 Receiver
Lightning Storm/Affinity Washer
During a lightning storm, a lightning strike could have induced a high voltage surge in your incoming power lines. Left unprotected from these power surges, the weakest link ( normally low voltage electronic controls) are the most susceptable. Just because you had power available at the wall receptacle after a storm doesn't mean that your washer control system wasn't exposed to one of these surges and got damaged. On the contrary, it is extremely likely that the washer took a 'hit' and was damaged.Other devices plugged into the same receptacle may have survived that hit because electricity travels the path of least resistance.. In this case.. that path may have been thru your washer.. My point being is that your washer could have sustained a power surge and was damaged so don't rule that out. Of course, that surge could have taken an internal fuse or other component out too..
Jul 17, 2008 | Frigidaire Affinity ATF7000E Front Load...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
80 people viewed this question
Seeker5211
Seeker5211
