Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a model L120 with 149 hrs and the service light is on. Is that for an oil change? also how do i make the service reminder go away after I service it?
I just changed the oil and filter on my LX420 twin cam how do I get the blinking light to go out. Its a 2006
  • The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display.
  • The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time.
  • CHG"/"OIL"/TIME will alternate on the display for five (5) minutes after the meter reaches 50 hours.
  • While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five (5) minutes.
The display will also flash as described above for five (5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two (2) hours.( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...)
THE METER DISPLAY WILL RESET TO NORMAL AUTOMATICALLY, after the reminder maintenance time interval of two (2) hours. There is no method of manually re-setting this Service Monitor gauge.
May 01, 2017 | Cars & Trucks
Service engine soon light came on, and went and had it diagnosed and nothing came up, what is the problem?
Service engine soon light, is the oil change reminder. Whoever changed oil on your vehicle needs to reset this reminder manually every time you get it serviced. Hope this helps.
Feb 29, 2012 | 2006 Saturn Vue
I changed the oil in my Craftsman Lawn Tractor 24HP Model No 917-288320 and the "change oil" message on the LED screen won't go away. Is there a reset button somewhere?
Below is excerpt from the owners manual:
SERVICE REMINDER/HOUR METER
Service reminder shows the total number
of hours the engine has run and flashes to
indicate that the engine or mower needs
servicing. When service is required, the
service reminder will flash for two hours.
To service engine and mower, see the
Maintenance section of this manual.
NOTE: Service reminder runs when the ignition
key is in any position but "STOP". For
accurate reading, be sure key remains in the
"STOP" position when engine is not running.
It should reset the 2 hours has expired
Jan 16, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mhy wife jus drove 200 miles and the the maintance light came on We're 300 miles away from my next oil change in my 2007 honda pilot. Could she get home without a problem?
Sure she can drive it. That light is only a reminder for you to service the vehicle, not a warning. Red lights are warning lights that need immediate attention. Yellow lights are reminders.
Nov 13, 2010 | 2007 Honda Pilot
I have a Sears - Craftsman 24HP 46" deck with a B&S Platinum V-Twin cylinder OHV engine. The diagnostic screen is referencing a "C86" issue than says OIL. I've checked the oil and the...
This is a predesigned message automaticly displayed at 50 hours, for oil change reminder. It doesnt know that you changed it. It will shut off within 10 hrs. It will come back on at 100 hrs. Its just a reminder.
Hope this helps
Nov 11, 2010 | Garden
How do i reset the change oil light on a 1040 cub cadet 1000 series
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Aug 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
ERROR MESSAGE CH6 SHOWING MODEL YTH2042
The YTH2042XP mower does display a message every 25 hrs which reads in full 'CHG OIL'. It is short for, and a reminder to, 'change the engine oil'.
Jul 18, 2010 | Husqvarna Garden
Why maint req´d driver in my car lit? what´s it the problem?
Maintenance required light is a reminder to change the oil. if you have had the oil changed within the last 3000 miles its likley the people that did the oil change didnt reset the light, if im not mistaken, to reset that light turn the car to the key on engine off position and hold the odometer button down until the light blinks and goes away
Apr 09, 2010 | 2005 Honda Civic
What does "service" light mean?
The service light comes on every 5000 miles to remind you to change the oil & check fluids. It is reset with a special tool that connects to the OBDII connector.
Jan 18, 2010 | 1998 Volvo S90
Husqvarna iz4817 change oil light needs to be reset
The oil change reminder will flash at 49 hrs for 2 hrs then reset itself. It will do this every 50 hrs.
Jun 30, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
70 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
