Question about LG Washing Machines
How to disable beep/chime on front loading washing machine: TROMM
SOURCE: tromm washing machine, front load from LG
I am getting an OE message during the washing cycle in my LG Tromm washing machine. What does it mean and how can i fix the problem?
bscavella@sbcglobal.net
Posted on Feb 17, 2009
  • 113 Answers
SOURCE: LG TROMM WASHING MACHINE FRONT LOAD
Here is text of very helpful email from LG
When you receive the LE error code, unplug the machine for approximately 15 - 20
minutes. This will reset the microprocessor.
The LE error code can be an indication of several different issues.
The most common cause is over-sudsing in the machine. Many times owners
experiencing the LE error code are using regular detergent. It is recommended to
use a high efficiency or low sudsing detergent. Many of the leading detergent
manufacturers have a high-efficiency (HE) selection. The HE detergents are
designed for lower suds levels and enhanced cleaning performance in
front-loading washers.
Overloading the wash with too much laundry may also cause the LE error code. A
good rule is to load the washer until the clothes in the drum are no more than
three-fourths of the way up the window of the door. This will allow them
sufficient room for tumbling. The clothing having sufficient room to tumble is
more important than either the weight or the number of items in the washer. It
is the tumbling action that provides the washing effect.
Lastly, a breakdown in the signal between the microprocessor and the motor may
cause the error code. This can occur if there is a loose wire, dislodged ball
sensor, or if the shipping bolts are removed prior to situating the washer. . In
this case, a servicer would need to take a look at the unit. In this case, you
will need a service center to look at your unit. For service assistance, please
visit our website at us.lgservice.com Click on "Service Center". Enter your
zipcode and product type. Click search.
In the event that you cannot find a service center, please call 1-800-243-0000
for assistance. There, an agent will be able to provide you with an Authorized
LG Service Center in your area.
Please have your model and serial number available along with your zip code when
you call. If you have a customer service issue, please let the agent know and
they will set up a customer service file for you. If your unit is under the
factory warranty, your purchase receipt will validate the warranty.
Business hours are 24 hours a day, 7 days a week.
I have taken the liberty of providing some hints and additional information that
may be helpful concerning your LG washer.
If you must use a regular detergent, you will only need to use 1/2-1/3 the
amount you would normally use in a conventional top-loading machine. However,
the HE and the conventional detergents are different formulae, and your machine
will not perform as efficiently or effectively. Using half the required amount
of regular detergent will
give half the cleaning performance. As the new LG washers accept a larger than
usual load, the cleaning performance could be further reduced. In addition to
the reduced cleaning, there will be oversudsing. The excess suds will cause the
washer to stop and rid itself of the suds before continuing its cycle. Getting
rid of the detergent will further reduce cleaning performance.
Using too much detergent can cause a build-up on the outer drum over time, which
can result in mold and even mildew growth in your washer. Should this occur, do
a load of whites on the SANITARY cycle. Use the extra rinse and stain options.
Use NO detergent and use a liquid bleach. This will remove the build-up and any
odors accompanying it. This procedure may need to be repeated a couple of times
depending on the degree of build-up.
The washing time may vary by the amount of laundry, water pressure, water
temperature, and other using conditions.
The 'SenseClean Washing System' has a built-in turbidity sensor that measures
the detergent/suds residue in the water during the rinse and then makes an
adjustment of time and water usage based on the detected residue level.
The machine will detect an imbalance and attempt to correct it. If the imbalance
is detected or if the suds removing program operates, the wash time will be
increased.
A built-in water heater in the washer assures that incoming water is the correct
temperature to optimize cleaning performance. Most laundry detergents must be
activated at certain temperatures to work correctly. We use thermisters
(electronic thermostats that have a high degree of accuracy) to detect incoming
water temperatures. Our 1000-watt heater adjusts the incoming water to ensure
superior thermal action performance.
You won't see a "visible" water level in the window of the unit. The water is
pooled in the inner drum. RollerJets are built into the baffles of the washer.
The holes in the baffle collect water and re-circulate it during the wash. This
increases the mechanical action to achieve best cleaning performance. The
rollers gently move fabrics
along in the wash cycle.
This action aids in reducing the amount of water required for thorough
cleansing. In contrast with a top-loading machine, which always fills the
machine to a precise measured level of water, depending on the size of load you
select (small, medium, large), the LG machine will "sense" the size of the load
and only recirculate a minimal amount of water, thus making it very energy
efficient, efficient in the use of detergents, and extremely efficient in its
water usage.
Forced Water Circulation in the washer pumps water during the wash. It
recirculates it back up and over the laundry to further increase mechanical
action and cleaning performance.
With front loading washers, the door seals so very tightly unlike a conventional
machine, that it is recommended to dry the seal when you are done with your
laundry for the day to prevent an atmosphere where mold and mildew can grow.
To get the best results, sort clothes into loads that can be washed with the
same wash cycle. Different fabrics need to be washed in different ways. Always
sort dark colors from pale colors and whites. Wash separately as dye and lint
transfer can occur causing discoloration of white clothing. If possible, do not
wash heavily soiled items with lightly soiled ones.
Combine large and small items in a load. Load large items first. Large items
should not be more than half the total wash load. Do not wash single items. This
may cause an out-of-balance load. Add one or two similar items.
Hope This help
Good Luck!!!
neo
Posted on Feb 27, 2009
MNTECH
  • 1543 Answers
SOURCE: Lg Tromm washing machine drum will not turn
the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Posted on Mar 01, 2009
t00nz
  • 4738 Answers
SOURCE: HAVE A LG TROMM FRONT LOADING WASHING MACHINE THAT SHAKES WHEN SI
Front loaders are prone to vibration problems. Don't want to go into the technical details of why, but it's important that they're placed on very solid surface (preferably concrete or tile), and checked that their feet have been adjusted so that the machine is level. Unfortunately, most people don't have a concrete pad for their washer. One simple option to consider is to provide dampening of the vibrations. This can be done very simply as shown here. The main thing to keep in mind with this solution is that it is merely trying to dampen the vibrations. Don't be too forceful in your own solution (think lightly touching the top of a vibrating tuning fork with your finger to stop the tone).
Posted on Nov 08, 2009
drsn
  • 42 Answers
SOURCE: TROMM Washer "CL" Error Message
THE CL ERROR CODE IS CHILD LOCK, PRESS AND HOLD THE PREWASH BUTTON FOR 3 SECONDS AND IT SHOULD TURN OFF........ BUT IF THERE ARE OTHER BUTTONS TO PRESS TRY IT OUT, THE OLDER LG'S HAD TWO BUTTONS TO PRESS, SO IF YOURS ARE THE OLDER ONES TRY IT OUT..... IF THIS HELPED OUT, PLS LEAVE A FEED BACK. I DO NOT ACCEPT PAYMENTS FROM ANYONE ONLY FEED BACKS, IT MOTIVATES ME TO HELP OUT OTHERS WHO NEEDS HELP....................
Posted on Feb 13, 2010
Water remaining in detergent dispenser on LG Tromm front load washer?
The water usually drains from the drawers just by gravity. Have you checked that your machine is level?
Nov 19, 2014 | LG Tromm Front Load Washer And Dryer Set
Lg tromm washing machine
If the machine still works and that is the only problem I would use it till it doesn't, really they cost so much to fix sometimes
Sep 01, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Jul 20, 2009 | Washing Machines
Water remains in detergent drawer
bpkaplan - did you find a solutiion? I have the exact same problem with my LG Tromm WM2477HW front load washing machine. It is about 2 1/2 years old.
Nov 24, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have an error code on my Tromm front loading washing unit that says LE. What does it mean? It won't complete it's wash cycle.
My husband opened the back panel and gave the drum a spin to get it going again. I believe ours errored due to being unlevel.
Nov 20, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG Tromm washing machine WM1812CW keeps coming up with error 0E. how can I fix it.
what do the letters UE mean on my Tromm front load washing machine?? PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I P
Jun 01, 2008 | Washing Machines
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
281 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
