Question about Refrigerators
Hello,My fridge is leaking blue liquid stuff and it is not getting cold.Thanks
5 Suggested Answers
SOURCE: leaking fridge ge
1) Check to make sure nothing has spilled in it. I had a bag of peas split open once and they were blocking some area and causing an airflow problem. I would then get Ice build up then it would thaw and spill on the floor.
2) I'm sure you have done thisw but make sure a water line does not have a split or pin hole.
Posted on Nov 17, 2008
  • 159 Answers
SOURCE: freezers too cold leaks h2o to fridge now fridge wont cool
because of too less gas in the system it cant make cool enough too switch off the compressor
Posted on May 22, 2009
  • 13 Answers
SOURCE: Freezer box gets cold but fridge box stays warm.
Could be frost build up in the freezer compartment or a bad defroster,
Try running a diagnostic defrost cycle test and see what happens
Posted on Aug 17, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Fridge and freezer not getting cold.
Is the yellow substance oil? I need the sears model number also for example 312.65989 That way I can picture just what you have on this end. Sea Breeze
Posted on Feb 21, 2010
My refrigerator is located in a fold garage ... A whitish liquid is leaking from the bottom of it ... Any idea what could be wrong
What you're seeing may be the oil in the system if the refrigerant system has failed leaked out - which I suspect it has.
Refrigerators do not work well in cold areas, as when the fridge's interior is cold and the compressor shuts off, the ambient temperature causes the refrigerant gas to turn to a liquid and return to the compressor. When the temperature inside the fridge rises enough to turn the compressor on - it fails catastrophically as a compressor can only compress a gas, not a liquid.
Mar 06, 2015 | Refrigerators
TBX21CIBRRWW the freezer works but the frig is not cold enough
Hello
the problem you are having with your fridge can only be caused by 3 things 1 your fridge has a gas leak 2 your fridge dryer may be blocked 3 your fridges compressor may have lost its sufficiency
you will have to get a tech to come and fix your fridge.
thanks
May 29, 2011 | Refrigerators
Hi, freezer took a dump two days ago, fridge was still fine. Then 12 hours later the fridge dumped out too. The compressor is hot and the relay looking thing with part number nsk 85851 clicks on for 20 sec...
most likely the start device is bad,look at the left wall inside the fridge near the cieling,you should see a model number,call your parts store,give them the model number on the machine,there is other letters after the g and tell them you need a start device.unplug the machine,until you get the part so you don't damage the compressor,it's not cooling anyway and thhe freezer feeds cold air to the fridge side,a fan blows cold air from freezer to fridge so next time if the freezer has a problem the fridge side is gonna have a problem too,unclip the metal clip and slide the start device off,read the instructions and it will tell you how to install the new device
Feb 06, 2011 | Maytag PTB2153G Top Freezer Refrigerator
Feb 21, 2010 | Kenmore Refrigerators
Fridge been moved in car now plugged in light on but not cold
Hello! Thanks for using FixYa!
I'm going to give you some troubleshooting steps you can use to see what is wrong with your fridge.
When plugged in, do you hear the compressor running? If not there is a problem with the compressor, either mechanically or not getting power.
If you hear the compressor running, but the fridge is not getting cold, check the back and see if there was any leakage or breaking of the pipes, as this would cause the compressor to not gain the proper pressure to cool your fridge.
If there is no damage to the back, and the compressor is running, then it is internal, then a repair man or someone with knowledge of the system will have to get to the insides and check everything in there, connections, breaks, loss of compression, leaks, wires and all that good stuff.
We appreciate your review and hope our answer has been sufficient and to your personal liking! Happy Holidays!
Dec 10, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Aug 17, 2009 | Refrigerators
Leak in fridge from between fridge roof and freezer, fridge is still cold as is freezer however will not stop leaking
Hi, The drain hole located in the freezer defrost drain is plugged. Get me your model # and I can assist you further.
THanks
Vic
May 17, 2009 | Refrigerators
Evaporator problem on refrigerator
if you have a gas leak then you find the liquid boil off very early in the evaporator only, there should be no visible frosting until after the end of the capillary
May 15, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge running but not getting cold
it seems like you have a minor gas leak
May 07, 2009 | Refrigerators
Blue fluid leak
There is no blue fluid in a refrigerator.
Something external or a add on is causing the blue fluid.
Mar 13, 2009 | Kenmore Refrigerators
Refrigerators Logo
948 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
