Question about Everex IMPACT GC2500 PC Desktop
My monitor turned off now when I turn it back on the screen is blank an the green power light just blinks what can I do?
    Scholar:
  • 128 Answers
Did you heard any beeps?..I may suggest to remove and put the video card back in for it can be a video card issue.. if this did not work you need to contact the manufacturer of your computer to have it warranted.
Posted on Sep 10, 2010
My screen symtoms are a little different on my L1975NW.
I am guessing the LED power indicator blinks green then becomes steady when the screen "turns on" (shows video). The problem is most likely a failing backlight power supply. That's why there is a 30 minute delay. Try to disable sleep mode and see whether that helps.
Aug 30, 2012 | Westinghouse L1975NW Monitor
Light on power on switch keeps blinking, screen blank.
Definitely a problem with the monitor. If you can get the back open then look at the main board and the power board. You will want to look for puffy capacitors. Instead of a flat top it will look puffy like its pregnant.
If you find any like that then you need to replace them with new capacitors that have the same Uf rating and at least the same voltage or higher.
This will take some unsoldering and soldering skills. Make sure the stiped edge gets aligned with the striped edge on the board.
If you replaced them then the monitor should turn back on. If it doesn't then its a screen problem and you'll need to get a new monitor.
May 01, 2010 | Acer AL1716 17" LCD Monitor
SVA Color TFT LCD is white on start up but goes blank.
when i turn the computer on the light on the monitor blinks green but i cant get it to turn on..i have a black screen.
Jan 16, 2009 | Computers & Internet
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
LCD blank screen, blink white
blank_page Use a reset sequence on the monitor-
1. turn off monitor
2. unplug power
3. plug power back in, holding down the last button on the left, then push the power button to turn back on and off three times, holding on the third try until it comes on- hold for ten seconds and release; the monitor should work again
Jul 28, 2008 | Computers & Internet
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Blank screen
its cheap buy a good one!!!!!!
Dec 22, 2007 | Computers & Internet
Everex IMPACT GC2500  PC Desktop Logo
Top Everex Computers & Internet Experts
Jerry Umali
IT Solution
IT Solution
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
