Question about Philips Magnavox 42MF521D/37 Television
Magnavox 42mf2310/17 dead bule light on
Magnavox tv when the power button is pressed the green light comes on but nothing else happens; there's no picture or sound or nothing; but the green light simply stays lit (no blinking).
first, press the channel -/+ button on the TV. If that doesn't turn on the TV, then it means you have to replace the bulb of your TV. The bulb is most likely dead.
Replace the bulb and your TV should be restored.
Let me know if you need further assistance.
Regards.
Aug 12, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Flashing Bule light on the front of my protron 32"
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem....
Jun 26, 2011 | Protron PLTV-32 Television
Magnavox 47MF437B/37 works fine until turned off. The red standby light comes on but the TV will not turn back on again. I have unpluggged the TV then plugged it back in again. Sometimes the the TV will...
Hope it work with the solution
Jun 12, 2011 | Toymax Magnavox 47MF437B 47 in. LCD TV
The power button shows dim blue light instead of regular deep blue. the light panel shows yellow light insted of all bule lights
this could be a simple ram prob, try removing the ram via the back door underneath the lap top the try rebooting, or find the cmos jumper and reset the bios/ cmoss settings, if the ram is not the prob it may be the graphics card has died, hope this helps
Feb 13, 2011 | Toshiba Satellite A100-S8111TD Notebook
I think my Magnavox DVD/VCR is dead. How can I
remove the small screws from the sides, back and bottom. Take the top cover off by sliding to the back and tilting up slightly. You should then see the disc drawer with the disc in and some cogs to one side. You can manually wind the cogs with a small screw driver to open the drawer.
Feb 07, 2010 | Philips Magnavox DVD/VCR Dual Player
No sound, no picture. tried unplugging and plugging back in...same problem. the green power light just keeps blinking 14 times over and over again. tv is around 11 yrs old...philips magnavox 32" smart...
check your h-out transistor, in high voltage area, capacitors and resistors, need reservicing and resoldering....hope you can do it, or check out with qualified tech
Oct 25, 2009 | Philips Magnavox TS3260C 32" TV
Bule lines on hdtv
The WS-55613 is not a DLP television. If this is the correct model number then you need to replace IC8C01 and IC8C02 part# STK394-250. They are located on the main board (in the middle of the chassis) and are mounted on a large aluminum heat sink.
Jun 08, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Motorola blutooth
the factory defualt pin is 0000
Sep 30, 2008 | Motorola Mobility H700 Wireless Headset
Philips Magnavox 42MF521D/37 Television Logo
95 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
