Question about Frigidaire FER641FS Electric Dryer
The dryer is running fine but is not heating at all. does the heating element need replacing
  • Frigidaire Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Posted on Sep 11, 2010
GE profile dryer,Runs fine but no heat
need to have the heat element checked with a multimeter and visually if u can and look for burns and corrosion and breaking of the wire connections. Also have the thermostats checked, Im assuming its electric and not gas? the thermal cut off may be bad and the hi-lo thermostat, these can shut heat off from the dryer. Ive replaced the element on my G.E profile and it wasn't all that hard rather simple.
Sep 13, 2014 | GE Profile Gas Dryer Model Dpsb513gb0ww
Dryer not heating, but the heating element looks fine
If it is a 220V. dryer.. it needs 2 fuses. One runs the dryer motor and the other one runs the heating element. Check the main fuse box. Turn off main power before messing with any fuses. Look for 2 big fuses, probably in their own block. You can switch these 2 around and try the dryer again. If it does not come on, then the fuse is bad and needs replaced. If nothing is any different, then the element may need replaced.
Oct 13, 2009 | Roper Dryers
Kenmore 86870800 Will not heat...
The reason to this problem is due to the faulty heating element.
Once the dryer runs with no heat then there is a problem in the
heating element which cannot be repaired,so you need to
replace it.
Sep 01, 2009 | Kenmore 63942 Dryer
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer is running fine just not getting hot
It sounds like the thermal fuse or heating element are defective. Both components are easily checked with an ohm meter or multimeter. The fuse is usually inside the back of the dryer by the exhaust duct. Both components should have continuity, if not they need to be replaced. Sure hope this helped.
Jul 20, 2009 | Roper REX4634KQ Electric Dryer
No heat out of dryer
HI, I just replaced an element in this model this morning. Remove the two screws holding front lower pane. The element is in a housing under the drum (right side). Check voltage to the two terminals while dryer is running and you should get 240V. If there is no voltage, you need to test the continuity of the thermostasts and safety on the blower housing (With dryer unplugged)
If there is voltage to the element, the element will need replaced. Part# 3387747. I have them on sale on my web site for $31.95 @ www.whirlpoolpartssurplus.com
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
May 22, 2009 | Whirlpool GEW9250 Electric Dryer
Motor runs fine, heat element will not heat, replaced heat element, no luck. Safety's checked out, timer ok.
Make sure where you dryer plug cord hockes into the dryer has 220 with a voltage meter read from left one to the right one should get 220 from right one to middle you should get 110 and from left onetto middle you should also get 110 the dryer will run with 110 but will not heat
Mar 28, 2009 | GE DBSR453EBWW Electric Dryer
Frigidaire FER641FS Electric Dryer Logo
73 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
