Question about Poulan WeedEater Hedge Trimmer 25cc Engine
I just put new fuel line on my trimmer now i cant start it not getting fuel the line never fills with fuel but i can **** fuel out so i know it not pinched it a weedeater brand ght-17
  • Desktopsbyduck-Computers
    Try reversing the fuel lines at the carb.RICHARDM69
  • 11,896 Answers
Make sure the little valve under the tank if you have one is fully turned clockwise. Make sure there is nothing clogging the tiny screen inside the fuel tank. Check or test your primer bulb it may be leaky. If carb or intake is leaking, you won't get gas either. If you have a filter on this model, try changing it.
Posted on Sep 10, 2010
Just brought new mech choice 25cc petrol line trimmer put petrol with oilmix in ,follwed instructions cant get it to start why,did we miss something out in getting it to start
How did you mix the fuel? Best to make it up in a jerry can. Mix the fuel and oil in the can. It may well be flooded. Try starting with ignition on, choke open and full throttle, might take up to ten pulls.
Sep 26, 2013 | Craftsman 25cc Gas Line Trimmer
Wont start
If the same fuel is in it try draining and re filling with fresh fuel, if no better to rule out an ignition issue, spray some fuel oil mix straight down the carb throat, if it fires up it is still a fuel issue.
Jun 16, 2012 | Craftsman 25cc Gas Line Trimmer
My 25cc craftsman weedwacker will not start it is not getting fuel prim bulb will not fill up lines are full of fuel when i pull them off new lines took csrb off and blue out with air. if i put fuel min...
Clean you needle/ seat inside carb pull apart and clean all out and try it off the w.w. to see if primer works ,also the primer has a check valve internally also make sure that is working, if the primer won;t pull gas through carb it won;t run 2StrokeJim
May 17, 2011 | Craftsman 25cc Gas Line Trimmer
How to get new plastic fuel lines in fuel tank in my weed-eater hedge trimmer. the line is larger than the hole in the tank.
Oftentimes it helps to use scissors to trim back a portion of the new line. Start at the bottom and cut upwards at an angle. Put some lubricant (WD40, perhaps) on the line and slide the sharp point into the fuel tank. Using needle nose pliers, grab the line and pull it through. This will only work if you have the correct size line. If the new line you are using is too large, you probably can't pull it through.
Apr 20, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Try to replace fuel line craftman weedwacker 32cc/1.9c.u -trimmer-hose all rotten cant figure how to replace
You will need to get some TYGON fuel line. Match it up to the size of each fuel line, some of these trimmer use two different size lines, and remember which size went on which connection. You will want about a foot of each. Cut one end of each line at a 60 degree angle. With a pair of needle nose pliers, feed the angled end of the fuel line into the hole going into the tank and feed it into the tank untill you can see at the tank fill. You cut the angled end off and put your filter on the line. Pull it back until the filter lays at the bottom of the tank. Hook this line up to the supply side of carburetor. Take the other line and put it in the tank about 1" or 2"
then cut it off to fit on the carburetor. HTH
Good Day.
Nov 10, 2009 | Craftsman 25cc Gas Line Trimmer
Craftman conv.wont start run when first start it soon dieded
sounds like you need a kit through the carby the diaphrams go hard if fuel is left in them for too long.
Jul 22, 2009 | Craftsman Convertible 25cc. Gas Line...
Fuel line for Toro trimmer
Hello:
You can Purchase Fuel Line for Trimmers and All Lawn Equipment at your Local Small Engine Service Center or your Local Automotive PArts Retailer.
Take a Piece of the Old Fuel Line so you Purchase the Correct Size.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 26, 2009 | Garden
Craftsman weedwacker won't start
When the Craftsman Weedwacker starts in idle and then stalls and the primer bulb will not fill with gasoline or will not pop back after being pushed in, then you have a blockage within the carburetor. The bulb is intended to **** fuel into the supply line, to prime it. To solve the problem, remove the carburetor, open the side that has ONE screw holding it (not the side with four small screws), remove all the two lines remembering how they were attached (the feeder line from the fuel tank attaches to the straight copper tube and the tube going to the bulb intake side attaches to the bent copper tube) and blow out the material blocking the fuel flow inside the carburetor. Then after replacing the carburetor, press the bulb and it should **** and discharge fuel easly. I have had two of these and the fuel path within the carburetor clogs easly. Jim Hart
Mar 13, 2009 | Craftsman 25cc Gas Line Trimmer
Poulan WeedEater Hedge Trimmer 25cc Engine Logo
645 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
