Question about Kyocera COPYSTAR CS-2050 Printer
Kyrocera cs 2050 error: call for service. Tech installed maintenance kit and now all we get is the error message.
    Problem Solver:
  • 11 Answers
Please provide call for service code like C- # # # #
Posted on May 02, 2011
How to clear the error replace maintenance kit
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
Mar 19, 2013 | Ricoh MAINTENANCE KIT TYPE 6330N...
The sprinter gives a message cleaning the paper path
Check* was paper physical length is matching to selected length? *check Maintenance kit interval. * check which tray you are getting this message? tray/tray 2 check pick up rollers are warn out? * clean paper path sensors.
Sep 30, 2011 | HP LaserJet 4250n Printer
HP laserjet 3600 error message 50.9 Fuser Error
Thank you for the inquiry.
Yes you will probably have to replace the fuser. If this is a new printer still under warranty and the page count has not reached the service life of the fuser, contact HP for warranty replacement. Once the new fuser in installed you will need to restore the service count.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=501046
Fuser Kit Part Number: (Sometimes Called a Maintenance Kit)
RM1-2665 This fuser is compatible with the following printers: HP Color LaserJet 2700, 3000, 3000N, 3000DN, 3000DTN, 3600, 3600N, 3600DN,
Link to Installation pictures and instructions:
http://printertechs.com/tech/mkinst/3000/mk-3000-2fuser.php
Restoring the maintenance count after installing new fuser.
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely.
To reset the fuser count :
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
The fuser count will be reset and then the printer is ready to use.
Thank you for being a FixYa Valued Customer.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 19, 2011 | HP LaserJet 3600 Printer
I have a print mode error on my Kyocera Mita CS-2050 KX How do I reset the copier?
what the error code ?
if c6xxx you need to rest by program 163 just tell me the error code and i'll help you
thanks
Aug 10, 2010 | Copystar CS-2050 All-In-One Printer
Top corner is a dots paper size A4
Have a service tech do a "preventative maintenance" kit installation and that will correct anything that would cause dots. (fixing unit)(drum)(charge corona)(developer unit)(transfer unit)
Jun 25, 2010 | Kyocera Copystar CS-5035 Copier
Message stating install MK
You have done more than 300,000 pages. I wouldnt waste your money on a Maint Kit, just stretch it out by doing the following.
Press Menu/Ok (Main menu)
Go into [>>Service]
Then press the right arrow.
Then find [>> Maintenance]
Press the ok key, then it will show [>> Maintenance?]
Press the ok key twice, and it will reset all the counts on your consumable components (Drum, Developer, Transfer Roller, ETC)
Oct 07, 2009 | Kyocera Copystar CS-1620 Black and White...
Ar 5631 showing maintenance required error
Press the :
( #/P ) key --> ( * ) key --> ( clear ) key --> ( * ) key
reset the maintenance counter: 24 start --> 4 start
Apr 07, 2009 | Sharp AR-5316 Advanced Digital Imager...
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
Unrecognizable error code
press 10871087 menu will appear then go to c codes list
Apr 09, 2008 | Copystar CS-2050 All-In-One Printer
Getting an display in the printer.
If you have the manual there is probably a section about this. It does sound like some parts may be wearing out and the printer is asking for new ones. Check out this link: http://www.printertechs.com/tech/maintcount.php A snip from the info there: If the display panel on your HP laserjet reads "perform printer maintenance", "perform user maintenance", or anything along those lines it means your printer needs a preventative maintenance kit, which includes a fuser and various rollers. Once you have installed the maintenance kit the message will only go away if you clear the maintenance count. For example the laserjet 4000 has a 200,000 page maintenance interval. Once you reach 200,000 pages the error message appears and you need to reset the maintenance count to zero to make the message go away.
Jun 15, 2007 | HP LaseJet 4350dtn Laser Printer
Kyocera COPYSTAR CS-2050 Printer Logo
131 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
