If those green wires have eye connectors on their ends, that indicates chassis grounds and should be put under one of the mounting screws on the board. you should be able to get a diagram from Behringer's website.
https://grounenimex.files.wordpress.com/2015/11/behringer-pmp2000-schematic-diagram.pdf
SOURCE: Connection of new circuit board to creda tumbe dryer TVR2
Nee
d more info. Need dryer brand, model and serial numbers.
SOURCE: i need a wiring diagram for the main circuit board
Behringer only gives schematics to their authorized service people.
I find I can usually trace stuff out as needed as the mixers are a very symetrical repeating circuitry.
Most components are readily available from other sources.
SOURCE: behringer pmp2000 europower no sound
Probably the power amp has arced and popped a lot of components.
When teh amps go usually the final pwer transistors, their drivers and sometimes even the power supply gets zapped.
Check the output of the preamp at the inserts for the final amp with headphones to see if anything is coming through.
SOURCE: the fuse and fuse holder
try googling the brand name to find the manufacturer, they'll have the fuse and holder. you can also try going to an electronics supply house, they'll be able to help you also.
SOURCE: Mine has 7 red blinks and wont come on. i pulled
No, your done. Now replace the Y-Main, that's the large one you found the fuse blown on and replace the two buffer boards that the Y plugs into. Those are the two at the far left. The part numbers are on the boards. So that's 3 boards you will need. sometimes they sell the buffers together as a pair which is cheaper. DO NOT buy from second hand resellers. Always buy new when it comes to plasma sets.
