Question about Samsung PS42P2ST 42 in. Plasma Television
Samsung ps 42p2st has audio out of sync - Samsung PS42P2ST 42 in. Plasma Television
I have a Samsung ps-wx30 surround sound system and I don't know how to connect it to my tv
Couldn't find PS WX-30 on the net or Samsung's site. Could you please confirm the model no.?
Jun 01, 2014 | Yamaha RX-V463 Receiver
Flshing AMBER Light, will not power up
it sounds there is a fault in your board. You should contact tech-person for servicing your tv.......Just an idea... wait some other expert will describe better.
Thanks
Iqbal
Apr 24, 2008 | Samsung PS42P2S 42 in. Plasma Television
PS 7200 SYNC WITH SAMSUNG S4 PHONE
Hello. When you pairing a blue tooth with a samsung if required a code it would be 0000 unless is a specific code by the manufacturer.
Fix: turn off the blue tooth on settings on the phone and turn it on. Let the phone scan for devices, if it says found p that should it. When you see it on the phone press on it, the phone and Bluetooth should pair by doing so. I hope this helps. Good luck.
Mar 04, 2014 | Samsung GALAXY S4
Streaming video audio out of sync
There is no way to fix this, as the new netflix app for android is meant for android versions 4.0 and up, and the galaxy tab not only lacks that version, but does not have a fast enough processor to process the audio and video, causing lag in the sync.
Dec 01, 2013 | Samsung Galaxy Tab Tablet PC
WHEN I CONNECT MY SAMSUNG YP PS MP3 PLAYER TO COMPUTER. IT DOSENT SHOW. Y IS THAT
install its driver ...if it doesn't have one ...it should be seen like a removable drive in My computer ..
http://www.samsung.com/us/support/downloads/YP-P2JAB
take a look on the videos that also explains about using the windows media player to sync with the mp3 player
Jan 13, 2011 | Samsung Yepp YP-P2 Digital Media Player
Samsung SYNC SGH-A707 Cellular Phone no sound even when starting . rings and recieve calls cant hear or talk.
Now you'll need to reset the audio from the phone's advanced menu, follow the following steps.
1. reboot your phone.
2. type *#0523#
3. keep tapping # till you see audio, which should be no 8
4. press 8
5. you can either rebuild the audio or reset the various audio options.
I hope that helps.
Jan 26, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Optical output on tv through dvd home cinema out of sync
Up front, i copied this from another site, so kudos to the OP there if this works for anyone...
This same problem had been bugging me when I bought my LE37B650, everyone suggested adjusting the delay time on my AV amp but unfortunately mine does not have this function.
Anyway I finally fixed the problem using the following steps
Before you start make a note of your menu settings as you will have to reset them after this procedure
Turn off the TV then press Info -> Menu -> Mute in sequence then turn the TV back on again. This will get you into the secret Service Menu. Go straight to the AUDIO page of the menu. Don't be tempted to fiddle with things in service menu cos you can end up in a right old pickle!
In the AUDIO page you willl notice that there is a time delay set for the internal speakers of 100ms but for some reason this is not set for the external output so all you need do is dial in a 100ms delay there and that should sort the problem. Well it fixed it for me.
Note that as soon as you enter the service menu, all your other standard menu settings are lost and the screen will be set to dynamic for some reason so you have to go through and change everything back after you have done this.
Hope this Helps
Original link: http://www.hometheaterforum.com/forum/thread/280579/audio-delay-on-samsung-650-lcd-tv
This would suggest that you CAN fix the problem with an analog amp.
Also interested to see if a 2 year old thread is alive!
Feb 09, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Ps-42p2st samsung plasma 42" does not power on!!
A computer cord is the same as the original. Go to any Radio Shack or TV shop and ask them to check the fuse to see if it is good or bad. If it is good, then suspect moving damage. If the fuse is bad, the person checking the fuse should be able to suggest a proper replacement. After replacing the fuse ( only if it checked bad), re apply power and hope the set comes on. If the fuse blows a second time, you need to call a technician. One other thing, some sets have a vacation switch that can accidentally get pushed during a move. Consult with the owners manual to verify if your set has one.
Jan 30, 2008 | Samsung PS42P2S 42 in. Plasma Television
No indication of power what so ever
Yes, a computer power cord is the same.
Without physical sign of damage, it will be hard to induce the movers to cover the problem. You will need to take it into a reputable TV shop and get their evaluation that whatever is wrong is due to the move. Its odd that it failed while off, however of course all these new TVs are not near as reliable as the old ones. Might just be a dislodged connector inside.
Hope Ya Fix It!
Jan 24, 2008 | Samsung PS42P2S 42 in. Plasma Television
Power swith ic went bang!
unfortunately these boards are now obsolete, it may have damaged the bridge rectifier
Nov 06, 2007 | Samsung PS42P2S 42 in. Plasma Television
Samsung PS42P2ST 42 in. Plasma Television Logo
103 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
