Question about Crosley CWDH11W Front Load Washer / Dryer
How to unlock the door of a CROSLEY cfw-8000gw. It is coming up with OE on the front and won't let me get the clothes out of there. How do i fix this problem
  • sheenahallin
    sheenahallin Jul 28, 2012
    when you pull the strainer out be prepared for water to pour out all over the place
  • 3 Answers
SOURCE: I have the Crosley cfw8000gr front load washer and
Open the small door on the front of the machine and take out the strainer for the pump i think you have something stuck in the pump also be carefull when you put the strainer back it is kind off tricky to line up.
Posted on Aug 27, 2009
  • 198 Answers
SOURCE: crosley digital front load washer
jus try to lubricate the lock n then try.... it wil work
Posted on Jun 17, 2008
  • 3 Answers
SOURCE: Crosley CFW8000GR OE Problem
Have you called Daewoo Customer Service they make this product for Crosley the number is 877-393-7823 Also have you checked to see if anything is stuck in the pump.
  • 2468 Answers
SOURCE: crosley front load washer one year old. doored
your drain pump or hoses are blocked with foreign material,either coins,hairpins,detergent residue from earlier washings,remove the front lower access panel if provided to access the drain hoses and pump and also check the drain itself,some washers have the access door in the back side of the machine,if the stand pipe in the house is slow to drain it can back up and cause back pressure and the machine will sense this and stop also
Posted on Nov 11, 2010
  • 6277 Answers
SOURCE: My front loading Crosley 8000GW
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 10, 2011
I HAVE A CROSLEY FRONT LOAD WASHER AND THE DOOR WONT UNLOCK, I HAVE TOWELS INSIDE, HAVE TRIED RUNNING ANOTHER CYCLE, PLEASE HELP
I have had that happen a couple of times and by hitting the pause or cancel button a couple of times it then opened.
Mar 05, 2014 | Crosley CW6000 Front Load Washer
My washer wont unlock so I can get my clothes out, and at the end of its cycle it flashes OE...how can i fix it?
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
Aug 11, 2011 | Washing Machines
My front loading Crosley 8000GW won't drain when it gets to the rinse spin cycle. I drained it from the drain hose and checked the filter. What else could it be? Thanks
John C
Mar 10, 2011 | Crosley CW6000 Front Load Washer
OE error code
Here's a link tot he LG site where the discuss the OE error and ways to resolve it...
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Jun 08, 2010 | LG WM1812C Front Load Washer
Jul 18, 2009 | Crosley CWDH11W Front Load Washer / Dryer
I have the Crosley cfw8000gr front load washer and dryer. The washer stops when its ready to drain and the letters on the dislay say OE. I have cleaned all of the filters and hoses however it still stops...
It won;t power up at all, clothes... Solve It won;t power up at all, clothes are locked inside, no lights on the panel. Plug in is working, I... (More) It won;t power up at all, clothes are locked inside,...
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2009 | Kenmore HE2 Plus Front Load Washer
Crosley digital front load washer
Jun 17, 2008 | Crosley CW5000 Front Load Washer
Crosley CWDH11W Front Load Washer / Dryer Logo
237 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
