Cars & Trucks Logo
Posted on Sep 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a honda civic, I had kept the car aside for a long time. Now that i have started driving again, i am getting a code error on the audio player, i am not able to use the cd player either. how do i get rid of the code error
Ruben Diaz
Level 3:
Master:
  • Master 514 Answers
  • Posted on Sep 10, 2010
Ruben Diaz
Master
Level 3:
Master:
Answers
514
Questions
0
Helped
160909
Points
1403
You need to re enter your code # to reactivate your sistem, or take it to the dealer for it. your battery died and did disable the sistem settings.
3answers
I have 99 honda civic that the rpm gauge is
At first I would suspect a VSS (Vehicle Speed Sensor) problem due to the flashing gear indicator and no speedometer. However, that won't keep the car from running. Check all the ground wires in the engine compartment.
2answers
At first I thought VSS (Vehicle Speed Sensor), which would explain the flashing gear indicator and no speedometer. But that wouldn't cause a no-start issue. Check all the ground connections in the engine compartment. And then under the dash if the problem persists.
Need code for the radio on a 2007 honda civic
ive posted this 12 times now (searches do work)
short answer, drive to honda dealer,
long it the guide,,,
here is lucky 13.
De'ja' vu , all over again. (LOL) RTM
RTM read the operators manual, its all there, here is a direct quote.
quote 13
2008 opr.guide.(lost it, huh?) Accord. non satellite Rad
Quotes:
Your vehicle's audio system may disable itself if it is disconnected from electrical power for any reason.
To make it work again, you must enter a specific five-digit code with the preset buttons.
Because there are hundreds of number combinations possible from the five
digits, making the system work without knowing the exact code is nearly impossible.
You should have received a radio code card that lists your audio system's code and serial numbers. {glove box find}
It is best to store this card in a safe place at home. In addition, you should write the audio system's serial number in this owner's manual.
If you lose the card, you must obtain the code number from your dealer.
To do this, you will need the audio system's serial number.
If your vehicle's battery is disconnected or goes dead, or the radio
fuse is removed, the audio system will disable itself. If this happens,
you will see ''ENTER CODE'' in the frequency display (on the screen on models with navigation system) the next time you turn on the system.
Use the preset buttons to enter the five-digit code. The code is on the radio code card included in your owner's manual kit.
When it is entered correctly, the radio will start playing.
If you make a mistake entering the code, do not start over; complete the
five-digit sequence, then enter the correct code. You have 10 tries to enter the correct code.
If you are unsuccessful in 10 attempts, you
must then leave the system on for 1 hour before trying again.
The system will retain your AM and FM presets even if power is disconnected. {only on newer cars'
General information on Honda and DIY:
{the code can be obtained from any Honda dealership (you must give him/her your radio serial number (sticker off radio)"}
or any locksmith with a license from..NASTIF
Honda1 ServiceExpress (Same info as ISIS)
Acura ISIS (Dealer version w/ advanced search)
http://nastf.org/i4a/pages/index.cfm?pageid=3462
There's an error with the stereo
Have you tried entering in your radio code? should be with your car manual?.....presuming it is the manufacturer fitted radio.
5helpful
Code for radio/cd honda civic 2003
Try to locate the unique code number that will unlock the theft-protected audio system on your 2003 Honda Civic. It probably was imprinted on an anti-theft identification card that you should have received when you acquired the car. The code was printed on a document that came with your owner's manual packet
If you do not have the code, you will need to track down the audio system's serial number. In the case of the 2003 Honda Civic, finding the serial number may require seeking assistance from a Honda dealer. The dealer should be able to determine the audio system's special code number so you can reset the radio. With some newer Honda Civic models, the serial number can be retrieved electronically from the radio.
If you are able to locate the serial number of your 2003 Honda Civic's audio system without a dealer's assistance, you can obtain the special code by going online to the Honda Web site. You must first provide specific information to prove you own the car. For instance, you will need the Civic's vehicle identification number, or VIN, and the audio system's serial number.
When you know what the audio system's special code number is, use the preset buttons on the car radio to punch in the digits. This should reset the audio system, enabling you to resume using the radio and the CD player.
Read more: How to Reset Radio Information on a 2003 Honda Civic ' eHow.com http://www.ehow.com/how_6056947_reset-information-2003-honda-civic.html#ixzz1FGPZq81d
I have a 2004 Honda civic that basically drops down to 5 mph after driving it for about an hour. The engine light will come on and then after a couple of hours its fine again to drive. It doesn't...
The check engine light comes ON,when there is error code stored in the car computer. to get car scanned at diagnosis center to get error codes, At diagnosis center you will receive the error code.As per the error code it will detect the exact faulty part in the car due to which the problem is occurring.For more help :--- at www.autozone.com its absolutely free to get car scanned. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
I have a 2005 honda accord that my daughter drives. the battery died. she tried to guess at the code, it now has an error of e2. how do i reset the error code so i can enter the radio code?
Most of the time the code is written in the manual. If not try calling a Honda dealership and they should be able to get it for you.
1helpful
3answers
My honda 1990 ex civic stalls at idle and while
try chage the gas filter i had the same problem and when i chaged the filter it fixed everything
1helpful
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
