We have a Franke FF-200r397 faucet that is locked on spray due to mineral debris in the faucet. Does anyone have a schematic they can forward or instructions regarding how to disassemble the spray mechanism so that I can clean the clog?
  • rszemraj9 Sep 10, 2010
    Thanks. I would think there has to be a way to take this item apart at least for maintenance or repair rather than having to replace the entire mechanism.
  • 10,865 Answers
Hi. Actually you won't have to disassemble it. Just go to the hardware store and get a bottle of CLR. This is a calcium, lime and rust dissolving agent that works great. Just follow the directions, soak the entire sprayer or faucet end in a bowl of CLR and it will dissolve the problem. Repeat as necessary. J.
Posted on Sep 10, 2010
    President:
  • 2,777 Answers
Hello there, sorry to hear about this issue you are having. Unfortunately Franke faucets are more obscure than the average faucet around... You are going to either need to contact Franke directly (which is tough since they are in Switzerland), or personally I'd start with an American distributor to see if they can help you locate such a schematic. It is proprietary information, safeguarded by Franke and is not freely available. I would start by calling someone like Kitchen's and Bath's in New Hampshire, phone number 603-893-6777. And possibly also email franke directly and see what they could do for you. You can contact them through their online form at:
http://www.franke.com/frankegroup/main/en/service/contact.html
My Franke FF-200 faucet does not swivel -
get the water main turned off , drain faucet then take top of tube off carefully. get a tub of vasoline and grease it put it back together and turn on water
Feb 13, 2015 | Franke Plumbing
I need a Franke faucet model # FF 822
I would try E-bay. Might also look for a rebuild kit. A last resort: Take it apart clean all the parts and then reassemble. Good luck.
Apr 01, 2014 | Franke Plumbing
How do I remove a seized handle on my FF-600 Franke faucet.
Refer to the link for drawing of the FF.660.
It looks like the Cover 45019 attaches to the faucet body I would brush some vinegar on/in any openings around this part for several minutes then heat the cover by pouring hot water over it after that use a Strap Wrench to try to turn the cover anti clockwise. It may take a few tries to dislodge the corrosion before it will release. Repeat with Valve 3699 and a wrench.
http://www.guillens.com/faucetparts/franke/images/FF600.jpg
Nov 10, 2013 | Plumbing
LOW WATER PRESURE FROM A FRANKE KITCHEN FAUCET
There probably is sediment where the water is coming at the valve. Remove the head of the faucet and clean it . This normally is the problem.
Dec 24, 2012 | Franke FF-303 Kitchen Faucet with...
Franke pull out spray broken
check to see if the weight on the hose got shifted too far back (if it was loose it could slide along the hose).
Feb 08, 2012 | Franke FF-303 Kitchen Faucet with...
Hello i have a franke kitchen faucet #fff303 and the spray head is not working is there a replacment head you can send me?
There are websites that give instructions for disassembling the Franke faucets. Also, some have a valve cartridge ($20-50) that can be replaced (you take the handle off, the catridge is inside)/
Jun 15, 2011 | Franke FF-303 Kitchen Faucet with...
It sprays fine but off the spray thair is no presuser . we replaced the water lines in the house we have good preasure though out our home jest not at the kitchen sink
One of the greatest things about Franke Faucets is that they have a lifetime guarantee. If you recently changed the waterlines in the home then more than likely when the water was turned back on or lines pressurized the settlement in the water main (Outside of your home) was activated and clogged the aerator. Most aerators simply turn counter clockwise (With the water off) after remooving the aerator simply clean and dislodge any particles in another sink. As for the pull out, some models have an inline screen located between the hose and the faucet handle. Simpy remove the handheld faucet (With the water off) and clean the screen.
Feb 02, 2011 | Franke FF-303 Kitchen Faucet with...
Trouble with a Franke kitchen faucet - the spout has a retractable internal hose for spraying down the sink - it is not retracting as it should
Look at the clutter under the sink. Is the hose tangled or caught on something? There should be a weight clamped to the hose to make it fall back into place. This weight minght have slid down the hose.
Jul 17, 2010 | Franke FF-303 Kitchen Faucet with...
Heating & Cooling Logo
120 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
