How to network a hp5610 printer to other computers via router
    Scholar:
  • 119 Answers
Ok you need to have the printer on a computer thats always on, Install then go to printer properties and share it with others on the networks, Its usually pretty easy to do, The link below is microsoft explaining how to do it, It really is simple don't over think it. Follow the directions below and let me know how you make out, If you need further assistance I will be more then happy to helo
http://www.microsoft.com/windowsxp/using/networking/expert/honeycutt_july2.mspx
Posted on Sep 10, 2010
Trying to connect hp printer to wrt150n
there are many ways to connect your printer with your linksys router:
connect your printer via ethernet cable.
connect your printer to the router via usb cable.
connect your cable to the router via wireless network
so if you are trying to connect your printer router via wifi method. then you need to go to setup on your printer and then go to wireless network option, once you will reach there then you will see there your network name and password you need to fill that network name and password on your router and then hit connect your printer will connected to the wifi.
if you have any kind of problem with any steps or you dont know your wifi password then you can contact to our helpline number :
Mar 10, 2014 | Linksys Wireless-N WRT150N Router
Connection of 6 computers to use one printer
A network printer can have many more connections. Most people have a wireless router that allow the whole household to use. The printer must have a unique IP address that was assigned by the router. From there the computer simply pints to that resource (IP via network cable) once it has been installed on each computer or device. Think of like a office setup.
Windows also allows for attached printers to be shared if the printer is not networked directly to the router (USB connected to PC), but the network setup still applies to the computers.
May 30, 2013 | Computers & Internet
I have followed directions for putting my HP LaserJet 4050 series PCL6 laser printer online via our home router. I have downloaded the correct driver. The printer shows in my list of printers, but w
1. Setup the printer with the router via network cable (This model is not wireless) on DHCP. The router should see the printer as a IP address on the web admin.
2. Next re-install or configure the printer via a network connection and IP.
Feb 11, 2013 | HP LaserJet 4050 Series PCL 6
Hi All, I am trying to connect Toshiba e-studio 207 via local network but unable to make it work.
Best way to Check is getca status page from your printer ,check the IP address that’s been assigned to your printer via dhcp from the router ,then just add the printer manually by creating a tcpip port with that op address
Oct 28, 2017 | Toshiba e-Studio 232 Black and White...
How do I connect my printer so that I can print wirelessly via my wifi network?
if the printer is within distance of your wireless router, run a network cable between the two. if the computer can access the wireless router it should be able to access the printer connected to the router.
Aug 26, 2011 | Lexmark X2670 All-In-One Printer
I have a WRT54GS router,also have A Wireless G Adapter, can i use
If you have the printer connected locally to a computer on your network, you can share it out and then connect to the printer share name via the network. Your other computers must be connected to your computers via wireless or wire.
Dec 27, 2009 | Linksys Wireless-G WRT54G Router
I have a new Compaq laptop running Vista home and an old samsung 4216f. I tried a parallel to usb and cannot get the printer to work. No parallel ports on laptop and no usb on printer. Any ideas?
If you have a home network, try a Print Server with parallel port. You will connect the printer to the print server via parallel, and the print server to a network hub/switch/router (any of the listed) via a network cable, and the computer to the hub/switch/router via network cable or wireless.
Cost should be around $20 - $60 depending on make/model.
Nov 30, 2008 | Office Equipment & Supplies
Set up 2 wireless routers, 1st for printer, 2nd for internet
You should only need one wireless router for everything. The purpose of the router is to "route" multiple devices together. Your set-up should be something like this:
Modem connected to wireless router via Ethernet cable.
Wireless router broadcasting wireless internet connection.
Computer(s) connected to wireless router via cable or wireless adapter.
Computer with network printer sharing enabled.
Turn on wireless printer.
You should be able to detect the printer via Windows.
Sep 05, 2008 | Office Equipment & Supplies
Network Connection (LAN) for HP 650C
Plug it directly into the router and set the printer up on your Win2k/Xp as a network printer via the new printer wizard. The router will allow it to pull an IP number and you will find it on the network that way. It does not have USB because it was meant as an office printer and the option was network adaptor when purchased. If you look at the card in it, you can see it can be swapped out for another adaptor.
Apr 26, 2007 | HP DesignJet 750c plus InkJet Printer
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
