Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
Food is freezing on refrig side. although i set at 46 degrees(fresh food) will drop to 26 degrees and freeze food
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
MAYTAG REFRIGERATOR MSD2756GEQ ALTHOUGH I HAVE THE TEMP SETTING FOR THE REFRIGERATOR SET AS LOW AS POSSIBLE , IT STAYS SO COLD THAT IT FREEZES MUCH OF THE FOOD .
They most likely problem is going the damper asm. that opens/closes to let air flow into the refrig.when is calls for cooling then closes when its cold enough. That damper is stuck open andletting in too much cold air. To repair that the damper assambly should be replaced ,the part # for it is 61005991 It fits in the upper left corner of the fresh food section,trying to close it some by hand now will restrict some air flow and perhaps everything wont freeze,until the damper can be replaced. It can be purchased at your local appliance parts store on online at
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
midwestapplianceparts.com
Aug 21, 2011 | Maytag MSD2758G Side by Side Refrigerator
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
The refrigerator side is freezing my food no mater how low i put the setting. compressor coils are clean
good you cleaned the coils but that would affect a no cool issue more. sounds as if either a thermistor has gone bad, or the damper door connecting the freezer and refrig compartments has failed and does not close properly. you would need to drop the cover off the control box inside the rear left top of refrig compartment and look at the vent behind it, perhaps ice has builtup on it preventing it from closing
Oct 09, 2010 | Amana ASD2627KE 26 Cu. Ft. Side-By-Side...
Refrig is freezing foods and will not stay set at temp recom.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
My refrig is freezing items on the refrig side.
likely a bad temperature control. also, some model GE's have a bad fresh food inlet cover, that fails to cutoff airflow from the freezer.
Feb 19, 2010 | Refrigerators
Refrigerator is freezing things at low settings
The thermostat ???? Without knowing what the original problem was, I can only guess that this the original problem.The cold control is only as good as the devices circulating the air in the refrigerator. You probably have a damper control problem. Make sure the damper between the freezer and the fresh food sections is operating properly.
Jul 01, 2009 | Refrigerators
No matter what i set the frig to it goes to 24 degrees and freezes everything.
Its funny you posted this problem as I have just finished working on a built in ge with the exact same problem!
any way whats happening is the dampers that control the quick chill area of your refrig arent opening and closing properly causing subfreezing temps in the fresh food comparment. the parts need to repair your unit are the air handler WR31X10023 and seal WR60X10116 these parts are abot 300.00 dollars. I would recomend calling a good service company to repair this for you but if your mechanicly inclined you could do it yourself. the airhandler is the component behind the crisper drawers in the fresh food section of your refrig.
Hope this helps and please post back if you have any questions thanks Peyton
Mar 05, 2009 | GE Monogram ZISS360NRSS 36" Built-In...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
362 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
