Question about NetGear WGR614 Router
My netgear modem WGR614 router keeps blinking yellow then goes to green a little. When its green I have a quick connection and the interenet works good. When it goes to yellow/orange the pages won't load and the link is often broken. I have had the router for about 1.5 years and has worked good till now. It just started doing this.
  • 109 Answers
Factory reset the modem and upgrade to the latest firmware.
Are you connected via ethernet or wireless?
Posted on Sep 10, 2010
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
Cannot connect to internet using wgr614 router. connection is good without router. with router connected, internet lite blinks.
To use a router with a DSL modem or cable modem, you need to connect the modem to the router at the WAN port and then connect the PC to one of the router ports. If the cable you have been using between the modem and PC is lableled as a cross-over cable, it is the wrong type of cable for the router connection. Use a straight through cable to connect the modem to the router.
If you do not have a manual for the router, here is a link to the router manual online: http://kbserver.netgear.com/pdf/wireless_router_setupmanual.pdf
The cross-over cable could be the problem (typically yellow cable).
Jan 20, 2010 | NetGear WGR614 Wireless Router
PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 20, 2009 | NetGear WGR614 Wireless Router
Netgear WGR614 router with USB Cable Modem
When working with routers, CAT-5 cables are the more usual cable used. Your modem's Ethernet Port --- connect it via cable to the router's WAN input. Connect one of the router's LAN outputs to your computer's LAN input with another CAT-5 cable. Go through the appropriate Router Setup by putting http://192.168.1.1 into your Internet Explorer, with ' admin ' for User Name, and no password (just press Enter in Password frame). Once you are in to the router setup, you can select your Network Name (SSID) and then implement whatever Security you might want to use. You should be up and running by now, nhave lots of fun!
Dec 18, 2009 | NetGear WGR614 Wireless Router
Router keeps loosing connection to computer maybe
sometimes the modem will kick off line, from a power glitch. I recommend you isolate the printer from that modem power strip and see how that works.
Nov 28, 2009 | NetGear WGR614 Router
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Connected to internet but cannot browse.
hi there ;
there is no such solution for ur problem ..... the only solution is to firstly reset the router for 30 seconds and then upgrade the firmware of the router ..... remove the powercord for 10 seconds ...
> Again redo the settings then ....
Nov 14, 2008 | NetGear WGR614 Wireless Router
Wireless not working...
are u using Netgear WGR614v5? if yes, the router has to be resetted as it hangs once awhile(dunno y). By default, the wireless is "OFF"
Jun 30, 2008 | NetGear WGR614 Wireless Router
WGR614-netgear-54 mbps-Plus wireless plug=in
Only real trouble shooting I can suggest is power cycle the modem and router. If you have the Comcast Digital Voice modem make sure you push the reset button on the back as there is a battery in the unit and unplugging won't do anything.
May 28, 2008 | NetGear WGR614 54Mbps Wireless Router...
NetGear WGR614 Router Logo
130 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
