Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Model KSSS42A runs most of the time. What causes this and what should be replaced? Freezer and fridge stays cold even on lowest setting
  • comerbd Sep 10, 2010
    Actually it is a KitchenAid model KSSS42A. I mistakenly wrote Kenmore. The thermostats for both freezer and fridge are set to lowest point. Everything stays cold or frozen but the motor or compressor runs 75% of the time.
    President:
  • 2,777 Answers
Can you give me a bit more detail on your problem, it runs most of the time? What about the other times? It just shuts off completely? No lights, no cooling, no nothing? How long do these periods last? How long has it been doing this? How old is the unit?
Thanks
Tim
Posted on Sep 10, 2010
    Brigadier General:
  • 3,917 Answers
Hi
You might try pulling it out from the wall, taking off the cover on the back at the bottom and cleaning it out. Take a look under the fridge and at the back to see if the coils underneath are dirty.If that doesn't fix it, check your thermostat in the freezer section. Turn it down a bit. If that's still not it, you may need to call a repairperson.
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Fridge started working again after I cleaned the grill, then freezer stoppped, unplugged and waited now freezer is good but fridge won't stay cold. The temp says 56. Ugh! Model # is PLHS67EGSB4.
My Freezer is Cold But My Fridge is Not! - YouTube
? 1:51
www.youtube.com/watch?v=OiKCqniraM8
Nov 5, 2013 - Uploaded by Appliance Princess What to do if your refrigerator is warm, but your freezer is stillcold. ... Cleaning them is a good idea, even if it isn't the cause, because it will improve the fridge's efficiency. ... How does thefreezer fan's failure cause a fridge not to stay cold? .... How To Fix Your Fridgidaire Refrigerator (if the compressor won't ..
Sep 23, 2015 | Refrigerators
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
Why do freezer coils ice up on my Stainless Steel Whirlpool refrigerator (model GB2SHDXTS)?
On your model your cntrl board has a relay that can stick causing the compressor to always run even when the unit is turned off or in defrost. turn the fridge off, move the temp of the freezer to it's warmest setting and it should display a line in the freezer and fridge temp display. listen to hear if the compressor is running in back of the unit. if it is you need part number: 12868513
Mar 15, 2013 | Whirlpool Refrigerators
Frc150ff fridge is too cold
You know that the lowest setting is the coldest .
Set it to 35 refrigerator, 6 degree freezer and see what haopen
May 27, 2017 | Frigidaire FRC150FFS
Hi, Have model E522B fridge, freezer cold but fridge even on lowest setting is only just getting cold. Can I fix it myself? Thanks for your help
The only thing a home owner can do to fix this is to make sure ALL the coils under and behind you fridge are clean. If that dose not work I would very strongly suggest calling a repairmen before you attempt to fix.
May 02, 2011 | Fisher and Paykel Active Smart E522B...
Temperature too cold even when on lowest
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Refrigerators
Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
May 19, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
35 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
