Question about Dishwashers
I have a model MDB7100AWQ, it fills with water but the motot won't start. Is there a reset code for this model? I did find a melted off plastic spoon handle in the bottom, could this cause it to trip something in the unit? The lights on the door switches come on but it only clicks, and won't start.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the door switch if that’s fine then you’ll have to replace the motor. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 10, 2010
Frigidaire plhs3teesbe model won't make ice
Hello - If your ice maker has stopped producing ice completely, you can try to check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Oct 03, 2012 | Frigidaire FRS3R5EMB Side by Side...
I have a emerson insinkerator that has nothing working checked breaker and reset button??no power??
First check that you have voltage at the outlet and that the switch is working. There is a reset button on the bottom of the unit - have you tried to reset that? If not, try it! If that doesn't do it, unplug your unit and use an allen wrench to rotate the motor (CW), if it won't turn then you either have something like a bone or spoon wedged in it or the motor is bad. If the motot is bad it is cheaper to replace than to repair.
Aug 14, 2011 | Emerson Vacuums
My Kenmore Ultra Wash 2 portable dishwasher is not filling with water, is there a screen or filter that could be dirty? It worked fine yesterday and I can hear the motot running, but it does not fill. ( I...
Check the solenoids on the water inlet valve. Often when they fail they get extremely hot and melt the outside housing. These are cheap to replace and can be done easily. I recommend contacting TheRepairClinic.com and using the online help feature to help diagnose the problem. They also carry a huge selection of parts, ship via UPS, and can give you specific advice on how to repair your particular machine.
Feb 24, 2011 | Dishwashers
Melted a spoon on element. What can I do to remove plastic on element
The way to remove it is you need to raise the temprature of the element to the level when the spoon melted, not so easy of a task, but nothing else will do it.
I would fire the element, and be ready with a damp terry cloth towel, and wipe the spoon free. Another way would be to use a propane torch, but you MUST protect everything around the element or you will cause more damage.
The key is that you have to acheive the same temprature that melted the spoon, and it will release and leave little, if any residue..
Feb 22, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
I a Westinghouse dishwasher 920 and a plastic spoon fell onto the element while it was on and its melted the spoon on the heat element and i cant remove it. how do i replace the element i am a motor mech...
Break as much of the plastic off as you can and just let the rest melt off or melt it with a solder gun . won't hurt anything. If you want is easy to replace just hall machine from hole and tilt back remove the wires and the nuts holding it on .
Dec 03, 2010 | Westinghouse Dishwashers
Plastic spoon melted on ceran stovetop. Used a
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Aug 24, 2009 | Whirlpool RCS3014 Electric Cooktop
WASHER FILLED WITH WATER AND STOPPED WORKING COMPLETELY
if you hear a motot running the coupling between the motor and transmission has disinagrated.
Dec 26, 2008 | Maytag MAT12CS Top Load Washer
Spoon
if it still is working and the spoon did not melt throgh the plastic. will work fine.
FYI my kids like watching bread ties spark up in mine
Oct 31, 2008 | Danby DMW1153 Microwave Oven
Fisher-paykel dd203 started filling with water with drawer open
what you can do is take a baster and empty out the water; then check and see if anything is at the bottom of the machine inside meaning under the thing that twirles and anything that is long put on top rack.Because you can something that is stuck or gunk that is blocking the way
Oct 23, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
MAYTAG DISHWASHER MODEL MDB7100AWQ
My MDB7100AWQ has suddenly stopped working. It will fill but then stops and will not move into wash. When I press the drain/off button the lights work but it does not drain. I do hear a switch in the door operate when I press the drain/off.
Jan 21, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Dishwashers Logo
52 people viewed this question
Top Dishwashers Experts
Owen Barnes
