Question about Canon EOS Rebel XSi Digital Camera
How to remove write protection from a disk - Canon EOS Rebel XSi Digital Camera
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 10, 2010
How do I remove write protection on a Dell XPS 8300 desktop - MBR corrupted, write protected
MBR means your WINDOWS or YOUR HARD DISK are dead!
Reinstall WINDOWS or replace the HARD DISK!
Aug 03, 2012 | Dell Computers & Internet
Windows was unable to format my flash disk
It seems that the card is bad. Try to format the card on a different machine to rule out your Windows formatter.
Aug 19, 2009 | Dell Inspiron 6400 Notebook
Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Jul 09, 2009 | PNY 2GB microSD Memory Card
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Disk is write-protected
You need to take uot the memory card, and slide the small tab on one side of the card that activates protect mode on memory card.
If that does nopt work, then memory card is faulty.
Oct 25, 2008 | Nokia 3230
Remove Write Protection
Remove Jet Flash Write Protection Insert the mini CD that came with the USB Flash disk. Start JF Utility.exe in the JF Utility directory. If it complains that the disk is write protected, choose "Continue" Choose "Partition" Answer "Yes" to losing all your data (Since this becomes a problem usually after formating the disk in WinXP or Win9x, you will most probably not have any data on there in any case) Choose "Public Area Only (Single Partition)", Then "OK", Then "OK" again. Unplug the device, reinsert device, and voila!- no more dark secret areas or write protection on your disk!
Oct 06, 2008 | Transcend T.sonic 610 MP3 Player
How to remove write protected memory card
when i attach the card reader with system and when i store the software or any thing in memory card then msg show that(cannot copy because write protected error)
Aug 29, 2008 | Nokia 3230
Canon EOS Rebel XSi Digital Camera Logo
294 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
