Question about Konica Minolta DiMAGE G500 Digital Camera
Camera displays a 'no card' message, tried differant cards but nothing seems to want to work !
  • daz_w69 Sep 10, 2010
    camera is a G600 'NOT' G500
  • 11,896 Answers
There is a couple different things you can try. One is to clean the memory slot contacts with a cotton swab or rubbing alcohol and a cotton swab. You can also check your camera setting to see if the memory options let you switch to memory card. You should also make sure none of the cards are locked. It is possible that the camera needs a firmware update.
Posted on Sep 10, 2010
Memory card error message
Cards are coming in different formats and it might be possible that you brought a card which is not suitable or functional with your camera. The other reason could be that we are having options to lock our memory card in digital camera and you might have taken out your earlier card without unlocking it. The system might be broken from inside and this could be a reason that you are still getting a message that memory card is locked. It seems possible based on problem you are sharing.
May 28, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Cannot unlock memory card for my Canon Powershot S5IS
OK take out the memory card and on the side of the card is a small switch...slide the switch to the unlock posistion and that should fix ya
!Please rate this response and help us keep this area free!
Thank You!
Jan 21, 2009 | Canon PowerShot S5 IS Digital Camera
Card Error Message
the error message is because the 2gb sd card is not supported (is too big for the camera)
try 1gb sd card and it should be fine
Jul 17, 2008 | Samsung Digimax 4010 Digital Camera
CARD IS LOCKED ON MY CANON POWERSHOT A420
I have a Canon A650 that was displaying a "card locked!" message. First, take out the card and check small the lock tab on the side of the card itself. Then, try a different SD card in the same camera. I tried an old 256 MB card from an older camera. I still got the "card locked" message. When I put the 1 GB card I was struggling with in my old Nikon, it read fine. So at this point I knew it was my camera and not the card. What finally worked for me was very gently pressing down on the metal flap inside the card chamber that detects the lock with the tip of a straightened paperclip. Hope this helps.
Jul 13, 2008 | Cameras
Unable to Use Card
My Z6 does the same thing every now and then.
The only way I can get the message to stop (and that annoying warning chime) is to pop the card in and out real fast with the camera turned on.
It seems as though these Konicas are REALLY picky with the cards, and this is a well known issue. Also, make sure the little "lock" tab is in the "unlock" position.
You can also try taking the batteries out, and holding the on/off button for 1 minute. That resets it back to factory defaults, and clears out any "bugs". Sometimes it helps.
Sometimes using a card reader and manually formatting the card works too.
Apr 06, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
Memory Card Locked
Do you have a computer that will read the "memoery cards"? Try reading the cards. If there is nothing on the card you still should get a message telling you the status. Check the setup of the camera. Some cameras allow you to lock the memory card from setup memu. You might also need to "format" the card before you use them.
Jul 17, 2007 | Casio QV-R41 Digital Camera
! Card Error Message
I've had similar problem when I was messing around with the Sony memory stick. The cheap pins inside that suppose to touch the memory got screwed up. I just bought the camera so took it back to the store and got a different one. Anyway, try shining a flashlight into the memory slot and see how the pins are. If they are not line up then use a really small something to re-line them like they suppose to. See if it's possible to reformat the memory. That sometime help too. It happened to my sis cell phone. We had to reformat the memory stick to get it working right. I do not think this have anything to do with battery. If you don't put memory in and camera say "No memory" and with memory in and it read "Mem error" then likely the reader or the pins are screwed up. Goodluck.
Aug 26, 2006 | Fuji FinePix 4900 Zoom Digital Camera
Konica Minolta DiMAGE G500 Digital Camera Logo
14 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
