Question about Samsung Computers & Internet
I cannot install the SmarTone Vodafone mobile broadband software. The message was "could not access VBScript run time for custom action". As advised by the SmarTone staff, I have tried recovery the system, disabled my firewall, used the command "regsvr32 vbscript.dll" and still without success. SmarTone staff said that they have no problem with intalling the software for the mobile modem in other brands of computer with Window 7, but just could not make Samsung's PC with Window 7 to work. Can you help? My Samsung computer: X130
  • 3 Answers
SOURCE: iTunes Install Problems
Hi, are you using Windows Vista? If so, go to the Start Menu, click All Programs, then Accessories, then right click on Command Prompt and select Run As Administrator.
In the box that appears, type: CD c:\windows\system32\ and then press enter.
Then type: regsvr32 vbscript.dll and press enter, then click OK.
Close the command prompt and try reinstalling itunes.
Hope this helps.
Posted on Sep 16, 2008
  • 3 Answers
SOURCE: Visual Basic Script not working
try an system restore from b4 the problem and then remove mcAfee, you can also remove some windows components and updates. when you got to the windows updates after removal it should re-install what it needs.
Posted on Mar 18, 2009
sach3000
  • 51 Answers
SOURCE: I get the following error message when trying to
run install to Administrator rights
Posted on Aug 20, 2009
SOURCE: Cannot see the message i typed in yahoo messenger
I AM LOGINE YAHOO MAIL SUCEES FULLI THE LOGINE PAGE ALL SO OPINIGE BUT MAIL WAS NOT SHOWING
Posted on Dec 21, 2009
  • 742 Answers
SOURCE: everytime i open iternet windows script host
It is a Windows Internet Explorer bug that could be fixed by upgrading your IE to version 8. Also, check your "home page"found at Tool => Internet Options and set it to some legitimate website. The error message simply means that the page you are viewing has scripts that return an error.
Posted on Feb 02, 2010
When advised [repeatedly] by Incredimail to update my version Of Incredimail 2, I finaly get a error 2738 could not access VBScript runtime for custom action. Any one help?
Microsoft has created a Fix-It for this!
What this Fix it does is to remove incorrect or corrupt registry entries that interfere with VB support in windows and then re-registers the DLL ensuring that the correct registry setting are there. After running the Fix it solution you may be able to immediately try the operation that previously gave you the error, but to be sure, a reboot is suggested. This will address similar issues with other programs as well and not just the applications that are specifically mentioned in this thread.
The link to the Fix it is: http://go.microsoft.com/?linkid=9804433
If you want to do it without any software then here is the Link to view the solution ERROR 2738
Aug 04, 2012 | Microsoft Computers & Internet
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
I have just activated Vodafone broadband on my new
did the software self install?maybe you need to updates it for your machine providing you have your account topped up.is the vodfone a prepay or contracted account?
If account then call vodafone,
if prepay,check sim card is working
also you could turn off your fire wall or set the permission levels on the fire wall to allow it to access the internet,
your anti virus protection levels may need adjusting also
Apr 26, 2010 | Vodafone Mobile Connect (055270) Wireless...
Cannot download itunes since a recent firmware upgrade for ipod touch, went to apple forum site and told to delete apple,quicktime, apple mobile device support and now i can`t get itunes to download onto...
Make sure VBScript is installed, turn off script blocking in anti-virus and personal firewall software, reregister VBScript, and then install iTunes." Resolution Download and install the latest version of iTunes.
Install the latest VBScript engine from Microsoft for your Windows OS platform Windows 2000 Download and install VBScript version 5.6 for Windows 2000 from Microsoft, and then try installing iTunes or QuickTime again. Windows XP Download and install VBScript version 5.7 for Windows XP from Microsoft, and then try installing iTunes or QuickTime again. Windows Vista No download necessary. The latest VBScripting engine (version 5.7) is already included with Vista. Follow the steps below to register the VBSScript again if you still have this issue in Vista.
Register the VBScript engine again If the latest VBScript engine is already installed, register it again. Note that you must be logged in as administrator or logged in as a user with administrator privileges for the computer to execute these steps.
For Windows 2000 or Windows XP: 1. On the Start menu, click Run.
2. In the "Open" field dialog box, enter the following command and click OK:
3. A message should appear stating that the "DllRegisterServer in vbscript.dll succeeded."
4. Click OK and try installing iTunes or QuickTime again.
Oct 19, 2009 | Apple iTunes
How can i set up my mms setting for nokia n86 in
Setting up MMS
1. Select menu button
2. Scroll and select tools
3. Scroll and select settings
4. Scroll and select connection
5. Scroll and select destinations
6. Scroll and select multimedia msg
7. Select options
8. Select new access point
9. When asked “automatically check for available access point” select no
10. Scroll and select packet data
11. When asked for packet data access point enter Vodafone MMS, and enter ok
12. Select edit
13. Scroll and select access point name
14. Delete any text, please enter
For Pay monthly customers: wap.vodafone.co.uk,
For Pay as you talk customers: pp.vodafone.co.uk,
and select ok
15. Scroll and select user name
16. Enter wap, select ok
17. Scroll and select password
18. Enter wap, select ok
19. Scroll to authentication and change to normal
20. Scroll to use access point and change to automatically
21. Scroll and select homepage and enter http://mms.vodafone.co.uk/servlets/mms, select
ok
22. Select options
23. Scroll and select advanced settings
24. Scroll and select proxy server address and enter 212.183.137.012, select ok
25. Scroll and select proxy port number and enter 8799, select ok
26. Select back twice
27. Select options
28. Scroll and select organise
29. Select change priority
30. Scroll to priority one, select ok
31. Select back five times
32. Scroll and select messaging
33. Select options
34. Scroll and select settings
35. Scroll and select multimedia message
36. Scroll and select access point in use
37. Scroll to Vodafone MMS, select ok
38. Select back four times
Let me know how you get on.
Sep 25, 2009 | Nokia N86 Smartphone
Hi, I have a Vodafone Access Gateway which I had connected to my Talktalk Huawei HG520b Router working on XP perfectly well renewed pc running Vista and now can not connect the Gateway as it keeps...
I had same problem as you have. Vodafone access gateway doesn't work with mobile broadband router since the data throughtput is not engough compare to landline broadband.
Sep 22, 2009 | Computers & Internet
Error 2738 when attempting to install HP F4180 printer software
Hi Stargateforg,
Try the solution from HP.
Solution one: Restart the computer
  1. Turn off the product.
  2. Restart the computer.
  3. Turn on the product.
  4. Use the HP software CD or the downloaded software file to install the HP Software.
Solution two: Register VBSCRIPT.DLL
  1. Search for the VBSCRIPT.DLL file on the computer. It is usually located in the C:\Windows\System32 folder.
  2. Click the Start icon (c01319360.gif ) , click All Programs , and then click Accessories .
  3. Right-click Command Prompt , then click Run as Administrator .
  4. In the command prompt, type CD C:\WINDOWS\SYSTEM32 . If the VBSCRIPT.DLL file is located in a different folder, use the appropriate folder location.
  5. Press the Enter key.
  6. Click Continue in the window that appears on the computer.
  7. Type REGSVR32 VBSCRIPT.DLL in the command prompt and press Enter . A message appears on the computer indicating that VBSCRIPT has been installed successfully.
  8. Use the HP software CD or the downloaded software file to install the HP Software.
Solution three: Download and install the latest version of the software
  1. Click here to go to the software download page on the HP Web site.
  2. Type the product model name in the text box and click the gray arrow button.
  3. Select the appropriate product model from the list that appears on the computer, then select the appropriate operating system from the list that appears on the computer.
  4. Under the Drivers section, click Full Feature Software and Drivers .
  5. Follow the on-screen instructions to download and install the HP software.
Solution four: Custom Install Use Custom Install to install the basic print drivers only.
  1. Use the HP software CD or the downloaded software file to start installing the HP Software.
  2. When prompted, click Custom Install .
  3. Clear all the entries in the list of software to install except Photosmart Officejet and Deskjet Drivers and Imaging Device Functions . Click Next to continue.
  4. Follow the on-screen instructions to install the basic print drivers.
Dec 22, 2008 | HP Office Equipment & Supplies
Error Message 2738 ipod shuffle install
Symptoms In some instances, the iTunes and QuickTime Installers may unexpectedly quit during the "Preparing to Install" stage of the installation with the following message:
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2738. In some cases, the error message may read
"iTunes could not be installed because Visual Basic Script (VBScript) is not installed or has been disabled. Make sure VBScript is installed, turn off script blocking in anti-virus and personal firewall software, reregister VBScript, and then install iTunes." Products Affected iTunes 7 for Windows, QuickTime 7 (Windows), Microsoft Windows 2000, Windows XP, Windows Vista
Resolution Windows XP or Windows Vista
Download and install iTunes 7.6 or later.
Dec 26, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Computers & Internet Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
