Question about RTO M-D Building Products Carpentry & Construction Box Beam Level 48"
My new panel door has been hung badly keeps dropping and rubbing floor also handle screws have come out and wont grip again.
  • 31 Answers
Please specify the type of hardware used for suspending the door. If you can take a photo of it, you may email it to nujazzphilosophy@yahoo.com ...be sure to reference this question.
Re: Stripped screws - Cut small splinters of soft wood (spruce-pine-fir) to size and glue them in the stripped screw holes. Allow to dry and cut/sand off excess. Refasten the handle with the screws using a screwdriver, or a cordless drill (w/screwdriver bit) with the clutch set to a low setting in order to prevent stripping again.
I hope that this was of help to you.
Posted on Dec 08, 2010
I am not an expert but I think you should check the wood because I think wood is too old which is purchased.
IHI Construction
Posted on Feb 08, 2014
Bosch SHE55M16UC/64 Dishwasher replacing control panel fascia or cover. How to remove chrome handle cover from old part and reinstall it?
You will have to take the door apart. Be very careful not to break any clips. The screws for the handle are on the inside of the door.
Mar 13, 2014 | Bosch Dishwashers
Door handle fell off of oven
Rachel, every range oven door I've seen, that was built in the last 20 years comes off the range by opening it about 6 - 8 in. from the top of the door frame, taking a firm grip on both sides about 8 - 10 in. down, bend the knees slightly, get a good grip on the door and pull up sharply. The door should release from the spring hinge on each side. Once you have it out you can lay it flat on the kitchen table, (preferably on a towel or cloth of some sort), with the inside facing up. There should be several screws that hold the interior portion of the door to the outer portion. If you remove these screws you should be able to remove the inner portion of the door, by pulling straight up, easily, and put it on the floor or if there's room, on the counter or table. Now you should be able to locate the holes the screws go into, to hold the handle on the door. If they connect from the interior, you should have found them when the interior was off the first time. Take them and install the handle. If there are none, find some chatterproof washers and put one on the inner side of each screw to keep them from loosening again. Once you have the handle secured to the door you should be able to put it back together. After you have assembled the two halves of the oven door, make sure the two hinge assemblies are pulled away from the frame of the oven at approx. a 35 degree angle. This is necessary to have the proper clearance to allow the door to slide down onto the hinges and grab on inside. The door should slide right down over the two hinges and then you can close it up.
Mar 05, 2014 | Whirlpool Ovens
How do I remove the window opening handle on. The drivers side of a 1989 s15?
there is a locking C clip between the handle and the door panel were the handle pivots on the regulator shaft.there is a thin plastic spacer that keeps the handle from rubbing on the door panel and sometimes the clip is between it and the handle.there is a tool specially for this but you can use a flat bladed screw driver and push the clip off of the handle groove that it sits in.then you can remove the handle.
Apr 29, 2011 | 1988 GMC S-15
How do I access the passenger hand grip bolts above the door?
Check and see if there are two small circles where you would put a bolt through the handle...generally they are there, covering the bolt head.
Jun 28, 2009 | 1997 Saturn SL
I am trying to remove the door frame on my 2001 Sonata. I have taken out the screws under the door handle and inside the door grip as well as along the perimeter of the frame, but the frame wont release...
roll the window down pry door panel along bottom and side edges. when clips are free lift up on panel the top edge has now clips or screws it wedges between window and door shell
Jun 20, 2009 | 1999 Hyundai Accent
Want to remove driver side door panel to gain access to power window motor
first remove the tweeter speker if equipped this comes off easily by gently prying from behind, then remove the small panel behind pull handle you"ll find a screw behind it\remove that,the next part is a little tricky the door grip needs to come off to achieve this place a small flat screwdriver at the top of the handle and pry forward the turn handle counterclockwise and this will release it from the clips you"ll then find 2 screws one at the top other at the bottom of door grip remove those and then gently pry from the bottom of the door panel to release the retaining clips thats it
May 31, 2009 | 2005 Subaru Outback
My passenger door hadle was pulled off when I pulled it to open it. I am trying to find a manual that explains to me how to change it. Can anyone point me in the right direction??? It's a Hyundai Tiburon...
These are the procedures outlined in the shop manual (without pictures). If you want the pictures too, go to http://www.hmaservice.com/ and register (by Vehicle VIN). Then you can navigate through the service manuals to find the info you're looking for. (You'll also have access to wiring diagrams, service bulletins, etc.)
1. Remove the grip handle using a remover.
2. Remove the inside handle housing.
3. Remove the tweeter speaker using a remover.
4. Remove the mounting screws and remove the door trim panel.
Disconnect the wire connectors.
5. Remove the door grip handle mounting bracket, speaker and door trim seal.
6. Remove the door tooling hole cover.
7. Remove the door glass stopper catch.
8. Remove the door delta chassis.
9. Remove the glass stopper bolts, remove the window glass.
10. Remove the door side weather strip.
11. Loosen the mounting nuts and remove the regulator assembly.
12. Disconnect the cable, after loosening the inner handle mounting screw, push the inner handle toward the direction shown in the illustrationand remove it.
13. Remove the door outside belt.
14. Remove the door outside handle and key cylinder.
15. Remove the door latch assembly mounting screws and remove the door latch assembly.
May 03, 2009 | 2003 Hyundai Tiburon
Outside sliding door handle?
Yes. It is a difficult job, but not impossible. The hardest part is actually removing the interior door handle. Here are the steps.
  1. remove the interior door handle by pressing the door panel in and prying out the C-ring retainer clip
  2. remove the lock slide switch bezel with 1 screw, then insert a blade on the bottom left of the slider between the slider and bezel, and release the clip, the slide the bezel toward the rear of the vehicle and pull out
  3. carefully unclip the door panel around the lower edge and sides and lift the door panel UP and off
  4. remove the interior lock slide switch with 2 screws
  5. pull back the plastic vapor shield part way to expose the mechanism
  6. there is a cable that runs from the mechanism to the exterior handle, unclip it from the door frame
  7. there is a rod that drops down from the door handle to the mechanism, release the rod from the plastic clip
  8. locate a large (likely black phillips) screw next to the door handle on the EDGE of the door, remove it
  9. locate a 10mm screw on the inside behind the door handle, remove it
  10. locate the final 10mm screw behind the handle through an access hole, remove it (careful not to let it fall inside the door)
  11. the door handle will push out through the door part way- there is another C-clip securing the lock cylinder that will need to be removed, and the lock cylinder can be pushed into the door cavity
  12. pull the door handle through the outside of the door skin- the door handle assembly is still attached inside the door by the latch cable- the cable can be easily removed from the handle assembly to remove it completely
  13. you will likely find that the end of the door handle itself is broken off- don’t buy a new handle! Email me and I will show you my free and possibly better solution that will likely last the life of the vehicle dbonnell1972 at yahoo dot com
re-assembly is the reverse of the removal
Aug 13, 2008 | 1994 Toyota Previa
Have a 2000 Cadillac Catera and the passanger rear window goes down but it is not coming up. Trying to find how to remove door panel and repair it. Any suggestions
There is a screw behind the ashtray of the door, and also another
in the armrest of the door.....underneath little cap. Once removed, the motor assembly can be removed by drilling the rivits out. The
replacement can be installed by using M5-0,8mm x 12mm bolts
and nuts (part # 44192 at Advanced Auto Parts. Motor assembly
for window was purchased at Salvage Yard for $40.
Jul 22, 2008 | 2000 Cadillac Catera
RTO M-D Building Products Carpentry & Construction Box Beam Level 48" Logo
67 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Vuk B
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
