SOURCE: My wife's Inspiron 8600 laptop
If you mean it happens every time after 5 minutes, then there must be a program running in the background which isn't noticeable or which you haven't noticed. After it's switched On, leave it for 5 minutes doing nothing, only leave Task Manager opened and watch the Processes list the the CPU Usage. I would also like to know which antivirus program or similar programs are installed on your computer.
It's always important to first diagnose the Softwares/Programs before dealing with the Hardware(s). It could be Hardware as well, but since you didn't mention anything about software or programs, let's try just one time as a verification.
Please don't forget to click the "Show Processes from all users" in the Processes section of the Task Manager. If you see any program which utilizes the maximum % of CPU, then note and terminate if possible (End Process Tree) and see if that helps or not. Definitely you'll be able to notice something in the Task Manager.
Let me know the result. All the Best.
SOURCE: safe mode....unsafe.
Your PC is stuck in safe mode startup
I would suggest using the Windows Disk, if you have one, go through normal windows installation. At the point of installation just after pressing F8 it will detect windows exists and offer you a repair option press R to repair
SOURCE: The following message appears as soon as I turn PC
There should be a jumper beside your bios batery there should be 3 pins move the jumper to the last 2 pins for 5 seconds and put it back that should do it
SOURCE: phoenix bios D686 (1999)
Go to the BIOS setup and find the Boot Seuence. Select Hard Disk first and if Hard Disk in blank, Boot from CD and install Operating System. This error usually comes when BIOS do not find the Boot Record on Hard Disk. ([email protected])
