Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
Is Blue tooth headset Plantronics Explorer 210 compatible with k790i. I got this headset recently, but am unable to pair with my Sony Ericson k790i mobile. Please help?
    President:
  • 1,118 Answers
Your headset must be in paring mode, in order to be paired with your phone. If, after turning it on, the indicator light doesn't alternately flash in red and blue (thus indicating it is in pairing mode), it has, most probably, been paired to another phone before. In this case, turn it off, wait for the indicator light to turn red, and, then, off. Then, turn your headset on again, and hold the call button until the indicator light is flashing alternately in red and blue. Either way, make your phone's bluetooth application search for new devices. After a while, your headset should appear on-screen. Make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process has been successful, your headset will enter the stand-by mode.
Hope it works for you.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Posted on Sep 10, 2010
Unable to turn on my plantronics 210 explorer bluetooth .therefore no light is showing in it. charger is fully charged
Sep 06, 2012 | Plantronics Explorer 210 Wireless...
Is the plantronics 232 headset compatible with the HTc Inspire
The Plantronics Explorer 232 is compatible with the HTC Inspire. Once you make your phone discoverable, then put the headset into pairing mode by pressing the call control button until it flashes red and blue. Here is a link for the pairing instructions:
Plantronics Explorer 230 Pairing Instructions
Good luck from Headsets Direct!
Oct 06, 2011 | Plantronics Explorer 232 Bluetooth Headset
Need to pair my nokia5310 to plantronics explorer 210
You don't mention if this is your first time pairing the headset, you will need to turn on your blue tooth on your cell phone, the light on the headset should come on flashing red/blue. If it does not refer to sub pairing instructions below. The cell phone should find the headset. 2XX Plantronics in your list. If the pass key is needed it is (four zeros). Second time pairing or more than one device, turn on bluetooth feature, headset turned on, press and hold the call button for about 5-6 seconds. Release button and set headset aside. On cell phone hit bluetooth menu, search for add device. The cell phone should find the headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 17, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Plantronics 330 unable to get the bluetooth in discovery mode
Once you make your cell phone discoverable, then put the Plantronics Explorer 330 headset into pairing mode by holding the call control button until the headset flashes red and blue. Click on the link below for the Explorer 330 user guide with the pairing instructions.
Plantronics Explorer 330 User's Guide
Jan 05, 2011 | Plantronics Explorer 330 Headset
I have a Nokia E75 and am unable to pair my Plantronics Explorer 210 with the phone. I tried to hold the big button down for quick pair mode. When I try to pair, it says unable to create bluetooth...
hello,
Step One:
Prepare Phone-
Turn on Bluetooth
For most phones, go to Settings/
Tools menu and select Bluetooth
or Connectivity and select "On."
(Or see the user guide for your
phone.)
Step Two:
Prepare Headset-
Pairing Mode
Step Three:
Pairing-
Add Headset to Phone
For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device,
then Select "220Plantronics."
For passkey enter 0000. Headset
will flash blue when paired
successfully. It is now powered on
and ready to use.
Begin with headset turned off. Turn
headset on (hold call control button
for 2 seconds until the light flashes
blue) and it will automatically go
into pairing mode, flashing red
and blue. hope it works
regards
shaun
Oct 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
390 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
