Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
My digital camera canon ixus 70 is having a black screen problem
SOURCE: CANON FAULTY SCREEN IMPORTANT READ ME
I have read that there seem to be many issues with no display on the LCD in playback or photo mode. What can I do to get this resolved? Thanks you. Greg
Posted on Sep 15, 2008
t00nz
  • 4738 Answers
SOURCE: I need a Canon Ixus 70 User's Guide
Go to Canon and download it. Here ya go:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=224&modelid=14901#DownloadDetailAct
Posted on Jan 11, 2008
parjee
  • 83 Answers
SOURCE: how to fix digital camera canon ixus 70 'lens
Would not recommend opening the camera as the chances are much greater for you causing greater damage. BUT would instead recommend that you try the seven sequential repair step outlined for a lens error in the below listed Related Link "Fixing a Lens Error on a Digital Camera". None of the steps outlined in this link involve opening the camera. and reportedly you should have close to a 50% chance of success with these techniques.
If you cannot repair the lens yourself with the first related link, then consider trying the two 'Digital camera repair" links below for two online digital camera repair businesses.
Posted on Sep 22, 2009
  • 102366 Answers
SOURCE: hi im using a canon digital ixus 9515 camera. can
This camera is designed to store images and videos to a memory card, not to stream them to a computer. It cannot be used as a webcam.
Posted on Jan 15, 2010
t00nz
  • 4738 Answers
SOURCE: Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Posted on Mar 20, 2010
Am trying to get a manual for canon digital camera IXUS 70 to see the seetings of the camera and the funtions of each button
Here is what you need.
manual for canon IXUS 70
* choose from 4 available manuals and follow download instructions.
If you want visual instructions, you can watch how it works from this video
instructional video for Canon IXUS 70
All I want in return is for you to rate this help. A 4 thumbs up is much appreciated.
Thank you for using Fixya.
Sep 08, 2010 | Cameras
Cropping on the canon ixus
Unfortunately, you don't. The IXUS 70 does not provide this capability. You'll have to use photo editing software on a computer to do this.
Jun 29, 2010 | Canon Cameras
Canon ixus 70 all showing a fuzzy dark spot??
clean the lens,get it serviced the lens as well as CCD.
Apr 10, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
I dropped my IXUS 70. Display screen has black section.
You have a bad CCD. The CCD is like film, it is what the light hits that actually convert an image to a picture. This is a repair as a rule that is more costly than what your camera may be worth.
Jul 03, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
IXUS 70 with black screen!
Did you accidentally press the lower-left DISP button on the back of your camera? This manually turns the screen on and off to save battery power. You would then use the optical viewfinder in its place. Try pressing the DISP button once to see if the screen turns back on.
Jun 20, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Black lcd screen on Ixus 70 shows icons but will not take picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon digital ixus 70 pdf manual
My Canon Ixus 70 will not switch on although the battery seems fully charged have you a solution please or does anyone have similar problems and their possible solutions thanks,
Bazzeruk
Jun 23, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon IXUS 70 Downloading to computer.
I've Canon IXUS 70.
My camera is full with images.
I can't download images to my computer.
Pls help me that:
How can i download the images from my camera into my computer.
Thanks in advance.
srinu
Dec 07, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
246 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
