Question about Peg Perego John Deere Gator HPX Ride on Toy
I have a gator 4 x 2 12 volt toy.... it had no low or reverse gear. I purchased a shifter and wiring harness.. I replaced them i still only have high speed. I also purchased a new motor can you tell me how to replace it?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
1. Remove the center caps from the rear wheels
2. use a 13mm wrench on each side and loosen the bolts
3. remove the rear wheels and axle
4. remove the red pin at the front of the dump bed
5. remove the two black pins at the rear of the dump bed
6. remove the dump bed
7. lift the green plastic cover off
8. remove the two screws that hold the gearbox and motor to the body
9. remove the gearbox and motor assembly
10. remove the two screws that hold the motor to the gearbox
Posted on Jun 13, 2012
SOURCE: kids john deere gator shifter won't go into reverse
I took the shift assembly apart. The switches weren't set in right. Once I put them in the shifter lined up and it works fine
Posted on Mar 20, 2009
  • 156 Answers
SOURCE: replace parts on ride-on toys
The gearboxes for both hummers and peg perego gators are under the back seat.
If you hear a clicking noise It is definatly the gearbox on the gator. The hummer gearboxes sometimes come loose from the motors, so it may be as simple as tightning the motor gearbox.
Here is how you take the gearboxes out from the gator.
1. disconnect battery
2. take hinge pins out from the dump bed to access the green cover plate.
3. take a flathead screwdriver and pry around the plastic cover to expose the gearboxes.
4. take the rear wheels off and remove the rear axle.
remove the motor gearboxes (they are interchangeable)
5. install the new gearboxes making sure the wires are secure and the wheels are going in the correct direction.
6. put back together.
7. hook up battery and your good to go!
If you have any problems are questions you can contact these guys at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html.
They have a toll-free number and are very smart when it comes to these peg perego ride on toys.
Posted on Apr 08, 2009
  • 19 Answers
SOURCE: Peg Perego Gator Ride On Toy
I had a peg perego gator hpx that was soing the same thing and I replaced both the high low switch and the reverse switch.
I found them at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
hope this helps
Posted on May 02, 2009
  • 156 Answers
SOURCE: Please let me know how I can change the rear tires
My Grandkids go through these wheels every few years.
They love their Gator.
You take the center black cap off and use a socket to remove the attachment on the axle.
Here is the replacement wheels
http://www.shopjandl.com/sarp8115kny.html
They can also help you with the repair, I call them all the time..very friendly people.
hope this helps
Posted on Sep 14, 2009
Testimonial: "Thank you so much for the info. "
  • 156 Answers
SOURCE: gator will not go in reverse or low gear only high
I would check to see if both wheels are spinning in high.
If only one spins, then it may have a loose connection on one of the motors.
You can also get the specific peg perego gator switches from the guys at
They also have a phone number that you can call them to explain the problem with the vehicle, they seem to know a lot about them.
Hope this helps.
Posted on Mar 18, 2010
Gator doesn't go in reverse
if both low and high gear work i would probably replace the shifter switch
Sep 04, 2011 | Peg Perego John Deere Gator HPX Ride on...
Gator wont go
No, just the shifter. Just to check you can exchange the red and blue wires under the pedal(just for a second or so, do not do this permanently) to see if you get power to the wheels, if so then yes it is Definitely only the shifter, but I am still pretty sure it is just the shifter. you can also call Peg Perego Tech support which is excellent and they can help you too 1800-728-2108 and parts can be priced and found at www.mypegperegoparts.com
Jul 31, 2010 | Peg Perego John Deere Gator HPX Ride on...
Both wheels will not move in high gear, only one wheel will spin, they both work in reverse and low gear
It sounds like you need to replace the peg perego switch assembly for the gator, I upgraded my shifter and it works great now, but I also found the additional switches at http://www.mypegperegoparts.com/
Jun 03, 2010 | Peg Perego John Deere Gator HPX Ride on...
Gator goes forward in reverse and reserve in forward. Battery is hooked up correctly
there should be a wire harness on the back of the shifter to go forward and reverse try to switch it around
Apr 19, 2010 | Peg Perego John Deere Gator HPX Ride on...
John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
They have helped me several times.
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
Gator will only drive in reverse
I would replace the reverse switch as seen in here http://www.shopjandl.com/mepu0003.html and also the high low switch for this peg perego gator.
Sometimes the high/low switch will cause it to not go in reverse, so I would replace both switches in the shifter just to make sure.
They are really easy to replace. You can call these guys http://www.shopjandl.com/.
They know what they are talking about because they sell and repair them.
Mar 28, 2009 | Peg Perego John Deere Gator HPX Ride on...
John Deer Gator only drives in low gear.
Sometimes the levers go bad in the shifter, but I would first check the shifter to make sure the switches are engaging. You should also check the wiring on the motors in the rear. Sometimes they come loose and if they are not making a good contact the gator will not go in proper speeds.
You can get great help at http://www.shopjandl.com/mepu0002.html.
They have a toll free number and are very helpfull because the repair them as well.
My son's gator will not go in reverse anymore.....When we first got it it did but as soon as we removed the screw for 2nd gear, it stopped....why
The problem is with the red forward/reverse switch. The two speed switch only works once the red forward contacts are engaged. I had the same problem several years ago. Replace the red switch and you are good to go.
Jan 08, 2009 | Peg Perego John Deere Gator HPX Ride on...
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
Aug 11, 2008 | Toys
PEG PEREGO JOHN DEERE GATOR
Problem #1:If you have taken the high speed safety device off the stick shift(small red plastic block screwed on below the yellow stick shift housing) then your high/low speed switch has gone out. There are two motors(one on each back wheel) that both have to come on when in high speed. Only one comes on for low speed. It is the switch under shifter that is not spring loaded. hi/lo switch #MEPU0002 available at www.tigerimports.net for $11.00 plus $2.00shipping That is where I got mine.
Problem #2: Sounds like you need hi/lo switch and possibly forward/reverse switch too. Before buying forward/reverse switch try putting a little grease on the white plastic assembly that engages the forward/reverse switch between the top piece and the piece that pushes down on top of the switch. Sometimes they just stick enough to stop switch from depressing. It is the switch under shifter that is spring loaded.Forward/reverse switch #MEPU0003 $11.00 plus $2.00 shipping @tigerimports.net
Jul 19, 2008 | Toys
Peg Perego John Deere Gator HPX Ride on Toy Logo
88 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
