Question about Microwave Ovens
NATIONAL NE-8180 Microwave: The timer is set and we push start, One second later it went dead almoust immediatley after pressing the start pad and show FFFFF on the display
SOURCE: the microwave starts, then stops 2 seconds later
I tried a solution posted on another posting http://www.fixya.com/support/t242480-stops_cooking by placing the conductive plastic behind the control panel and it worked.
Posted on Jan 06, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave keeps blowing fuse
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links with info on part testing:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by
entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Humming sound, F9 and dead
Seems like I answered this, but maybe it's a different poster.
The 721 model code means it's an LG/Goldstar-made oven and F9 indicates a problem with the inverter or magnetron.
Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models.
I would suggest you contact Sears for service.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave key pad stopped working
Okay, thank you for that.
You have a failed membrane keypad, but on this model, it is not available separately.
You would need to order the control panel assembly, part # WB56X10817, which you can get here for far less than GE charges.
It costs more than just a membrane would, but is much simpler to replace.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you remove your circuit board from the old frame and install it in the new frame.
Posted on Jan 03, 2009
SOURCE: Panasonic NN-H264 1200...stops after 3 seconds
I found sufficient information elsewhere.
Posted on Feb 13, 2009
My siemens microwave oven trips off almost imediately
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
See these links for more information:
Sep 02, 2013 | Microwave Ovens
NN 8501V Panasonic Dimension 4 Convection/Microwave oven keeps blowing fuse
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
Apr 16, 2013 | Microwave Ovens
Micowave goes on for few seconds then blows fuse. replaced magnetron tube and still does same thing
See these links:
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Apr 05, 2013 | GE Microwave Ovens
After push START bottom,fuse has over current & fuse damaged
May 25, 2010 | DeLonghi MW 535 Microwave Oven
I am trying to set the kitchen timer on my older spacemaker microwave for 2 hours and am unable to do so ... Am I trying to do something impossible?
The first step is to set the clock. To do this, push clock, set the time using the key pad and then PUSH clock a second time.
Once that is done you can set the timer by pushing timer, putting in the number of minutes you want and pushing start.
Jun 07, 2009 | GE Spacemaker Over-the-Range Microwave
Microwave fuse mystery
AHD_NZ
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Guest
We're happy to help and we appreciate your thoughtful rating of our answer.
May 28, 2008 | Microwave Ovens
Blown Fuse
Apr 01, 2008 | Emerson MW8775W Microwave Oven
Microwave Fuse keeps blowing
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Mar 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven just died
Once you've looked over the safety warnings, here are some useful links:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Jan 04, 2008 | Microwave Ovens
Jan 03, 2008 | Microwave Ovens
Microwave Ovens Logo
102 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
