Question about Microwave Ovens
I have a Home Bakery Unit (Model No. HB-D102) that has stopped heating. I have checked the heating element with a continuity tester and it ha checked out as NOT being burned out. What might be the problem? Is there a fuse in the system that might have blown>
    Genius:
  • 1,478 Answers
Some models may have a separate high voltage fuse. If this is blown, there will be no heating but no other symptoms. However, high voltage fuses are somewhat rare on domestic ovens.
A number of failures can result in the fuse NOT blowing but still no heat:
  • Bad connections - these may be almost anywhere in the microwave generator or the primary circuit of the HV transformer. A common location is at the crimp connections to the magnetron filament as they are high current and can overheat and result in no or intermittent contac.
  • Open thermal protector - usually located on magnetron case. Test for continuity. It should read as a dead short - near zero ohms.
  • Open thermal fuse - some ovens have one of these in the primary circuit. It may be in either connection to the HV transformer or elsewhere. Test for continuity. It should read as a dead short - near zero ohms. A shorted HV capacitor would likely immediately blow the fuse.
  • Open magnetron filament - This failure may also be due to loose, burnt, or deteriorated press (Fast-on) lugs for the filament connections and not an actual magnetron problem.
  • Defective HV relay. A few models use a relay in the actual high voltage circuitry (rather than the primary) to regulate cooking power. This may have dirty or burnt contacts, a defective coil, or bad connection.
Posted on Sep 10, 2010
Hamilton beach microwave model number hb-p100n30al-s3 left unplugged all night still won't heat. Buy a new one?
I would say so. if its not heating it can be a magnetron tube or high voltage inverter circuit. For the cost of repair its not worth it.
Oct 16, 2016 | Hamilton Beach HB-P100N30AL-S3 - 1.1 CF...
Microwave not heating up
If the microwave is not heating check magnetron connections, probably you will need to replace the magnetron.
Sep 06, 2008 | Microwave Ovens
Kitchen aid microwave will not heat
first check the fuse if cutoff, replace it. if ok, then check for any broken wire. if all connections are intact, then test the heating element for continuity, if no continuity, then the element is bad and needs replacement. try these steps
Jun 11, 2013 | Microwave Ovens
Need to find a manual for bread machine , brand name: Wel Bilt. model number:ABM1H70
Use your make + your model + your model number (omitting any dashes, slashes, or spaces) + the word MANUAL + the abbreviation PDF to perform an Internet search. Google is best for these types of searches.
Example: If you owned the Fredericks Home Bakery model KHB-178 you would want to enter your search as:
FREDERICKS HOME BAKERY KHB178 MANUAL PDF
Hope this helps & Happy Hunting!
Note: Breadmakers model numbers are usually located on the backside or bottom of the unit, either on a printed decal or raised plastic embossment, and usually followed by abbreviations such as mdl, mdl no, model, model no, type, style, art, art no, article no, cat, cat no or catalog no.
Jun 23, 2011 | Microwave Ovens
I need an owners manual and recipes for the hitachi bread machine HB-D103
Check out this download link (pdf)~9.04MB @ http://www.manualsonline.com/mdownloads/a2ff9b61-1c99-425a-90cc-fd40cb97bfd2.pdf (HITACHI AUTOMATIC HOME BAKERY - HB-D102/D103(USE & CARE MANUAL & COOKBOOK)
It will take quite a while for the pdf file to open & you can save the pdf manual on the PC & print a copy out later.
Hope it is the manual you needed.
May 27, 2011 | Hitachi Microwave Ovens
Oven not working. Replaced an element, but oven will not heat up. The stovetop works fine, but the oven does not heat up.
check the continuity or resistance.
Now if its zero reading try to check your termination and also check the fuse or thermal cut out or thermal overload if it is busted or burn try to used also your tester.
But if there a resistances try to reset.
Mar 04, 2011 | Frigidaire FMV156DC Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
