Question about Advent Computers & Internet
Can you give me instructions on how to repace the screen on an advent laptop K1301P. Thank you
  • 516 Answers
Check this..
http://www.moniserv.com/doc/part.htm
Posted on Sep 10, 2010
Advent 7111 narrow screen
If the display isn't going full screen, on that 15.4 inch TFT LCD screen, the problem is the screen Inverter, or LCD screen itself.
90 PERCENT OF THE TIME the fault is the screen Inverter.
It isn't a simple screen resolution setting that needs to be changed.
http://www.laptoppowerjacks.co.uk/advent-inverter/advent-7111-7107-8315-lcd-screen-inverter-as023217127-iv09140t-lf.html
Primer:
An LCD screen does not produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/Vikuiti1/BrandProducts/secondary/optics101/
It needs an additional light source.
The additional light source is a Backlight.
A Backlight can be a CCFL, or a series of LED's.
The Advent 7111 Notebook PC uses One CCFL,
http://www.screencountry.com/index.php?section=products&model=7111&brand=Advent&size=
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average size is 2mm Thick. Length is almost as long, as the LCD screen is in height. 2mm is close to 1/16th of an Inch )
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
Primer over.
I don't have access to a Service Manual, for the Advent 7111 Notebook PC. I haven't had one come to my shop for repair.
I DO have years of experience at repairing laptops, and I see the Advent 7111 is just a basic laptop, as I HAVE repaired over the years.
If you wish, I can guide you step by step, in replacing the screen Inverter.
(MANY people go out, and buy an LCD screen, when the problem is a much less expensive screen Inverter. Afterwards they buy the screen Inverter. Too bad they didn't come here first)
Post back in a Comment.
Regards,
joecoolvette
[ The Advent 7111 Notebook PC is just a re-badged Quanta TW3M.
According to the source, you should see TW3M on the bottom of the laptop.
http://www.uktsupport.co.uk/advent/laptop/7111.htm
May 20, 2012 | Advent Computers & Internet
I want to take my advent K1301P laptop back to factory settings but i dont have the disk is there any other way i can do it?
To restore your computer back to factory settings, follow the steps below:
  1. Turn on the computer and keep tapping F8 until the advanced options menu is displayed
  2. Use the up/down arrow keys on the keyboard to highlight Repair Your Computer and press enter to select it
  3. Select the language you wish to install (normally English is the only option)
  4. Once you have chosen your language you will be presented with the available recovery options
    • Microsoft Repair Environment - after choosing the UK keyboard layout you will be asked to choose the Operating System you wish to repair. If Windows Vista is not listed then you cannot repair the OS without doing the full recovery. After choosing Vista the Microsoft Vista startup repair tool will run and attempt to repair any startup problems you are experiencing
    • Reinstall Windows - gives you the options available to reinstall Vista
    • Advanced Options - this launches the diagnostic centre allowing you to run chkdsk, launch notepad or bring up a command prompt
    • Exit & restart computer - Exits withut running the recovery process
  5. To continue with the recovery program you need to choose Reinstall Windows
  6. On the next screen you have the ability to launch Vista System Restore and roll back to a date when Vista was last working ok or to run the Full Destructive Recovery. To continue with the recovery program you need to choose Start Full Destructive Recovery
  7. After choosing the Full Destructive Recovery option you are presented with the warning screen that all data will be lost. It is important to make sure all data has been backed up to disk if possible and to realise this process deletes all data and reverts the machine back to it's default state. To continue with the recovery program you need to tick the box indicating you are aware of data loss
  8. The recovery process will then run through, the computer will restart a couple of times during this. You will also need to go through the Vista "Out of Box Experience", to configure Vista. This is fairly straightforward so just follow the onscreen instructions
Jun 18, 2011 | Computers & Internet
The screen changes when i move it back and forth
thats the display is giving you sign for repacement
very soon the display might go blank so you have to change the screen ok
Mar 01, 2010 | Advent Netbook
My advent 5431 laptop windows vista setup hangs
often in vista installation, you have an option to install a driver, and then you put your driver disk in the drive and the Sata driver is installed. Then vista will install as it should . Give it a try..
Jan 19, 2010 | Advent Netbook
Advent 7098 faulty screen?
Angle the screen to the light. If you can see a faint screen image then it's probable that the backlight's inverter has either failed, it's cable has become damaged or the backlight has failed. Both of these can be tricky to replace unless you have the right tools, but can be done provided you can get a spare. Usually it's a tech job.
If the image is not there then it's either the screen itself, the graphics chip or, more likely, the ribbon cable that connects the screen to the motherboard.
You can rule out the graphics chip by plugging the laptop into a monitor.
Of course, the ultimate problem is that you've bought an Advent laptop! And most techs agree that Advent produce the worst laptops in the world. :(
Jun 07, 2009 | Computers & Internet
Manual
According to UKT support this is a rebadged Uniwill L75118
http://www.uktsupport.co.uk/advent/laptop/9117.htm
Gives a general spec sheet.
http://www.uniwill.com/UserDownload/l75ii/l75ii.php
Has a download for the pdf manual at the bottom.
I have one too and am busily trying to find out if I can upgrade the Processor.
According to the manual it is possible to have a t5700 2.2GHz processor in it.
dr_dazzit@yahoo.co.uk
Mar 16, 2008 | Recoton Advent Advent Q2035A 20" TV
Computers & Internet Logo
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
