This problem should be removed because:
Problem with Refrigerators
I have a Kenmore refrigerator side by side model 106.53582300, purchased Aug 2003. It's been working perfectly until about 3 days ago, very suddenly, neither freezer nor fridge is cold. There is
air blowing in from the vents, I did a through vacuum of the coils under the unit but I think it's warmer INSIDE the fridge than outside. I'm wondering if I should bother trying to have it repaired or just replace it. I can't understand how a fridge that's only 7 years old just up and died like this!
Solutions (1)
Best Solution
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Many times a freezer and/or refrigerator
do not work right because of a dirty condenser coil...there are also many other
things that can go wrong.
If you are hearing a clicking or buzzing then check out the
last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start
trouble shooting your unit...and something that you can do rather then calling
a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Testimonial: " Your perfect description about the start relay (& the pictures were great) helped so much! $60 for the part & my frig is alive again! Thank you!!"
Refrigerator power is on, but is not working
I have a side by side in garage, which is very cold. Fridge is on but not cooling either side. It does not come on when garage is very cold....
refrigerator not getting cold - freezer still...
refrigerator not getting cold - freezer still pretty cold - perhaps not all the way raphael@raphaelbachrach.com I purchased a Kenmore...
Fridge slowly gets warmer and stops working
The fridge seems to get warmer over a period of weeks and then stops getting cold. The freezer vents collect a large amount of ice in a...
Kenmore Coldspot model 106 - Snowing in freezer!
Kenmore Coldspot model 106 - HELP! Freezer looks like full of snowy blizzard. Ice on roof of fridge. Freezer vent not blocked. Cleaned...
Add Your Solution
Smeg Fab32 noisy
I just purchased a Smeg Fab32 from ebay and although the unit seems to be working correctly it seems very loud compared...
problem with refrigerator cooling
The fresh food section of the refrigerator does not go below 50F while set to max , and i read that it should be...
Installed a WR55x10942 in place of WR55X10473 now...
i have a GE Model Number GSH25JFRFBB refrigerator and the mother board i order is a WR55X10942. It is different from the...
I need a manual for a Siemens refrigerator...
It has a cold water dispenser on the front of the door
Fix-O-Meter
285
285 people viewed this problem
- 2 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Refrigerator Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
