Question about Koss Audio Players & Recorders
My cd does not play on my Kross 941. When I put the cd in to play the display shows DISC. Any suggerstion?
  • weistart418 Sep 10, 2010
    NO! CD's do not work. I have tried various CD's. When the CD is put in, 000 00 first shows then it blinks DISC. Do you know how to fix this problem?
    President:
  • 2,777 Answers
I assume it used to work fine? It may just be as simple as a dirty laser, but please confirm that this unit used to work properly and now does not? When was the last time it worked?
Let me know and I can definitely help, thanks!
Tim
Posted on Sep 10, 2010
    President:
  • 2,185 Answers
Have you tried playing other discs? do they play? if yes, then your cd you're having problems playing is faulty or it might just be not compatible. If your cd is DVD, make sure your player plays DVDs.
Please let me know how this goes.
When i put one dvd or Cd in the display Show Loading then ERRO disc whats happening?
if the discs did play before this happened you might need to have the laser inside cleaned,
get a laser disc cleaner and run that through it.
Dec 13, 2016 | Televison & Video
How do I set free play on my rowe laser100
Hi you put on service , then you enter 84 then you put the number of credit you want by example 9999 and you press popular and you put back to normal mode
Jul 03, 2014 | Wurlitzer Jukebox CD Player
KD-HDR40 will not play any CDs, only displays a "CD reading" message.
Sounds like CD mechanism failure. Did some sticker or anything went inside? Any way, need service.
Mar 03, 2012 | JVC Kd-hdr40 Car CD/ MP3 Player
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
RCA RS2664 Stereo wont play CD in any of the trays but seems to try to scan to play.
Hello
The laser pickup unit's lens may be dirty or dusty. Just put a lens cleaning disc into the tray, and play it at least three times, by ejecting the disc each time, and reinsert in in to. The lens cleaning disc can be bought from most of the electronic spare part selling shops at your town, and won't cost more. If it dose not help you, the laser pickup unit of your RCA device should be replaced with same type and number. OK.
Jan 25, 2012 | RCA RS2664 Shelf System
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
My Nx-385 will not play. When I put in a disc the player attempts to read then the display screen shows the word disc. What should I do?
It sounds like there is a problem with the Laser not picking up the CD.
If you've tried a Lens Cleaning Disc or Cleaned the Lens directly with a QTip and Lens Cleaning Fluid then the Laser has failed and wound not be cost effective to replace.
May 07, 2011 | Naxa Electronics NX-385 Personal CD Player
CD playing erratic
Run a "Laser Lens Cleaner" thru the unit a couple times. Use one that takes fluid, you can find them at just about any retail store for 15-20. If that doesn't solve it, it needs to be repaired. At that point weigh the cost over replacement. A new transport usually will cost 100-150 on average for parts and labor. Hope this helps
Jun 23, 2009 | Audio Players & Recorders
Denon CD unit will not play due to err
The problem is in the mechanism,maybe when you put another disc while playing that is cause. There is a misaligment there in the tray you better checked it out,and also the lense by using a cotton buds.thats all for now Hespbb....
Jun 19, 2008 | Denon Audio Players & Recorders
Alpine CD Changer - won't read CD
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Jul 30, 2007 | Alpine CHM-S620 6-Disc CD Changer
64 people viewed this question
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steven Wander
Steven Wander
Steve K
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
