I have a dell 3130. A few months old. Recently, the toner, especially black, hasnot been sticking to the paper peoperly. You can rub it off. Also, paper has been jamming. A little guide at the top has broken off and now the printer keeps saying 'paper jam' when there isn't any. Please can you help
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
Toner rubbing off could be caused by a few things. First, make sure you are using proper paper and genuine dell toner. If both of these are true and the problem continues you may need to replace the fuser. The part number is M508D. Iteminc.com has these in stock and ships same day. Here is a video that shows you how to replace the fuser.
Posted on Jan 03, 2012
  • 48 Answers
The fuser in the top of the printer is probably defective. The fuser is what melts the toner into the paper. The guide that you talking about may be part of the fuser as well.
Posted on Sep 10, 2010
WHY DO I GET ~ MARKS ON OUR COPIES WHEN USING DELL 3130
Those little squiggle marks are caused by a component in the toner cartridge. Some time ago the manufacturers changed a plain full width foam roller, to one that has a spiral of foam along its length. It was a means of shaving a few coppers off the manufacturing cost. It happens when the cartridge is a bit old (even though it might not have been used - some materials age) There are two solutions to this.
1. Change the cartridge.
2. Find an old cartridge with the old full width foam roller, and swap that (together with its supports) into the new cartridge. Works every time.
May 23, 2014 | Dell 3130cn Color Laser Printer
Toner not sticking to paper
If the toner rubs off the paper then the fuser unit is probably faulty. The fuser heats the toner/paper and fuses the toner to the paper.
Jan 14, 2013 | Xerox Phaser 6180N Laser Printer
Hi, I have a Dell 3130 Color laser printer. Every 10-15 print jobs i get a paper jam. The jam is at the exit where your grab the paper. If you can tell me what i can do to fix it that would be great.
in your paper tray can you check please if it is set correctly, also the paper that your using does it curl on exit? this could indicate damp or humid paper
Feb 08, 2011 | Dell 3130cn Color Laser Printer
BLACK STRIP ON THE LEFT SIDE ON MY PAPER??? I HAVE A HP LASERJET 1022NW....WE HAVE CLEANED AND BLEW OUT THE PRINTER....STILL NO IMPROVEMENT....WHAT TO DO NEXT....
Run the 1/2 print test.
Put paper in the manual feed tray. Print a few pages of anything. As the paper gets about 3/4 of the way into the printer, open the cartridge door. Pull out the cartridge and look down at the paper. If it has the black stripe on the left side, replace the toner. In fact at this point, pick up the toner cartridge and gently swing the shutter open and look at the drum. You should be able to see a black stripe on it.
By the way, the toner hasn't been fused to the paper at this point. It will rub off on hands and clothes.
If the 1/2 test shows no stripe on the paper...replace the fuser.
Dec 01, 2010 | HP Office Equipment & Supplies
I have a Dell 3130cn that consistantly has peeling toner on any type or weight paper and of course that causes black toner "slobbers" on the back of the next sheet. What the heck is going on? I...
hi there
thats an expensive printer -- you desrev some answers, direct from their techsupport
The printer is new, you should get in contact with Dell, as its under warranty
if dell has inconvenienced you that much, i would ask for free toner cartridge or something of value to compensate : they usally do that for customers
review the firmware information for the printer , see if you have the latest version, if not go to this link to download
http://support.us.dell.com/support/downloads/download.aspx?c=ca&cs=cabsdt1&l=en&s=bsd&releaseid=R269308&formatcnt=0&libid=0&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=396303
may this serve you well !
Nov 04, 2010 | Dell 3130cn Color Laser Printer
I have a new Dell 3130 cn printer. For the past
Sounds like the drum unit is damaged. Replace it. I mean not only the toner unit but the whole thing. Remember never touching these...
Oct 20, 2009 | Dell 3100cn Laser Printer
Dell 3110cn Color Laser Printer Certain colors will not adhere to the page when printed on heavy paper. Combination of green/black wipes off the paper when rubbed.
Either the paper is just too thick for the printer to fuse the toner correctly, or you've NOT selected the right paper type (in the printer driver options.
If you're just printing that same as you would on ordinary A4 paper, the fuser can't get enough heat through the thick paper to fuse the toner.
May be a wrong toner problem if you've done this successfully before, but only had this problem since changing toner cartridge(s)
Oct 19, 2009 | Dell 3110cn Laser Printer
My DELL 3010CN is printing a thick black line on the right hand margin on all pages printed.
Often Toner sticks to fuser. When the fuser heats the toner comes off onto the paper. Should reduce over time unless toner is spilling onto the fuser in the same place.
Change fuser and toner
thanks
Apr 08, 2009 | Dell 3010cn Laser Printer
Black streaks on copies from bypass tray and tray w/thick paper
Most likely you may of had a toner spill awhile ago and the toner may be biult up with in the paper path and it is draging in it. Also, it may have to do with the drum pick off claw unit. The paper may be rubbing against the unit with thicker paper. I would have your service person clean the whole paper path of lose toner and if they can bring another drum unit to test if the problem is in the drum unit it self. Good Luck
Dec 04, 2008 | Office Equipment & Supplies
No Print on Paper
It sounds like you need a new electron or electrode I forget exactly what they call it, this negatively charges the paper as it passes over the positively charged toner drum allowing toner too stick to the paper where required, the lower the negative charge is the less toner that can positively stick to the paper, creating a light black or grey print. This generally occurs with age but should not be too hard to replace by yourself, just expensive.
May 17, 2007 | Dell 5100cn Laser Printer
116 people viewed this question
jasbo
jasbo
